mirage Posted November 2, 2007 Share Posted November 2, 2007 I just picked up a set of used motolights caliper mount driving lights.The set came without instructions. Can anyone tell me which of the brake caliper bolts they are supposed to mount on a 1999 BMW R1100RT? Anyone have pictures of their installation? What length socket head bolt is used? Thank you. Link to comment
CLEAN1 Posted November 2, 2007 Share Posted November 2, 2007 Suggest you contact Motolights. They are very helpful. You cannot use just any bolt with the correct thread and length. Motolights supplies the correct strength bolts with their kits. They will probably sell you the correct ones for very little. They can provide the instructions as well. Link to comment
flat_twin Posted November 2, 2007 Share Posted November 2, 2007 I'm pretty sure they go on the upper bolt. Your 99Rt should be a 10mm bolt. The 1150's use a 8mm bolt and a different mounting base. Motolights will send you a new correct bolt for the asking. The mounts will cost you but not the bolt. Here's a link to instructions per Motolight. http://www.motolight.com/wysiwyg.php?id=7 Link to comment
Godfather Posted November 2, 2007 Share Posted November 2, 2007 They will charge you $10 for the bolts and shipping. Be sure to specify your bike, year and model several times to them, as I had to find out the hard way (3 attempts to get it right). They eventually get it, but it's frustrating shipping things back and forth. Instructions are on their web site. Also be sure you have the correct mounting brackets , the 1100's and 1150's have different diameter holes. Link to comment
mirage Posted November 2, 2007 Author Share Posted November 2, 2007 Thanks to all for the information, I am sending an email to motolights. Link to comment
mirage Posted November 2, 2007 Author Share Posted November 2, 2007 I am adding this to the thread for others that may search in the future for this information. Update from Motolight -Adding Brake Caliper Motolights to a 1999 BMW R1100RT: The caliper light can be mounted in either the upper or lower bolt position of the brake caliper, most people mount in the upper, unless fender or other clearance issues arise. The bolt size for a 1999 BMW R1100RT is 10mm x 1.5mm x 50mm you also need a 10mm lock washer. Motolight suggests that you order the bolts from them as their bolts exceed mfg specs. $10.00 including shipping. Thanks again to all that responded. Link to comment
