richard mauro Posted October 29, 2007 Share Posted October 29, 2007 WHAT SIZE HEX/TORK? ARE THESE SCREWS Link to comment
kiwiaudio Posted October 29, 2007 Share Posted October 29, 2007 Needs a 3mm hex key that should be in your kit. Link to comment
Wooster Posted October 29, 2007 Share Posted October 29, 2007 R1100RT uses 3 mm allen head machine screws of three different lengths: what an '03 R1150RT uses, I don't know. I bet you can tell if it's a regular allen head (perfect hexagon) vs a torq (sort of a star shaped interior where lines forming star curve inward). Wooster with plain/regular allen headed fairing screws (is this the 'hex head' I've heard so much about ?) Link to comment
Perlova Posted October 29, 2007 Share Posted October 29, 2007 As far as fairing screws are concerned, after they have been removed once, the paint gets chipped. So I used a wire brush and turned them into a brushed stainless steel finish. Much nicer now....... Link to comment
kiwiaudio Posted October 30, 2007 Share Posted October 30, 2007 I've always called them Allen heads, but more commonly in the USA they are called Hex heads I believe. Put a plastic washer under them and they won't chip your fairings paint. Link to comment
jfremder Posted October 30, 2007 Share Posted October 30, 2007 I've always called them Allen heads, but more commonly in the USA they are called Hex heads I believe. Put a plastic washer under them and they won't chip your fairings paint. "Button Head Socket Cap Screw" you can get a lifetime supply of stainless ones at McMaster You need both lengths. Or just wire brush the ones you already have. Pack 92095A212 Metric 18-8 SS Button Head Socket Cap Screw M5 Size, 16 mm Length, .8 mm Pitch, Packs of 100 $13.34 $13.34 today Pack 92095A214 Metric 18-8 SS Button Head Socket Cap Screw M5 Size, 20 mm Length, .8 mm Pitch, Packs of 50 $7.81 $7.81 today Link to comment
John in NC Posted October 30, 2007 Share Posted October 30, 2007 Does anyone have a source for the "U NUTS" the screws go in? Link to comment
John844 Posted October 30, 2007 Share Posted October 30, 2007 I have not tried these yet, or measured mine to see how close they are or which one matches best. Their descriptions sound pretty close. They are also from McMaster 95210A130 Metric Tapped-Hole U-Style Clip-on Nut M5 X 0.8 mm Pitch, for .8 - 4 mm Thick Panel In stock at $14.88 per Pack of 50 95210A120 Metric Tapped-Hole U-Style Clip-on Nut M5 X 0.8 mm Pitch, for .6 - 3.8 mm Thick Panel In stock at $5.61 per Pack of 25 Link to comment
Mark K Posted October 30, 2007 Share Posted October 30, 2007 95210A130 Metric Tapped-Hole U-Style Clip-on Nut M5 X 0.8 mm Pitch, for .8 - 4 mm Thick Panel In stock at $14.88 per Pack of 50 95210A120 Metric Tapped-Hole U-Style Clip-on Nut M5 X 0.8 mm Pitch, for .6 - 3.8 mm Thick Panel In stock at $5.61 per Pack of 25 That's particularly useful after road testing with the plastic off. Hope these work! Link to comment
