John844 Posted October 29, 2007 Posted October 29, 2007 I am new the the BMW world and just got my 98 R1100RT. My throttle seems stiff. Still usable and returns to idle, but uncomfortable after a few hours. The return to idle does appear sluggish like there is a slight drag or dampner on it. I checked the grip assembly and regreased it. The grease in there was really tacky and old, so I thought that was my problem. There is now no friction at that point. Are the springs on the throttle bodies really stiff, or do I need to dig deaper into lubing the cables and/or replacing them? There are only 15000 miles on the bike. If this cable can be lubed, I assume the tank will have to come off. There is only one cable attached to each throttle body, so the cable must split before getting there. I don't want any extra lube dripping all over the motor. Any suggestions or things I should watch out for?
Ken H. Posted October 29, 2007 Posted October 29, 2007 BMW cables are designed to run dry. If the cable itself is stiff, it is bad or there is a 'downsteam' issue. There is a junction box under the tank, under the ABS unit where the throttle cable pulls the two shorter cables to the throttle bodies.
John844 Posted October 29, 2007 Author Posted October 29, 2007 Thanks Ken. I noticed another thread where you just mentioned cleaning out that junction box. Can I just spray it out with brake cleaner, or will that be too harsh?
Quinn Posted November 1, 2007 Posted November 1, 2007 Do you, by chance, have a throttle miester on the bike? If you have a chrome weighted knob at the end of the handlebars, try screwing in the right hand one.
John844 Posted November 1, 2007 Author Posted November 1, 2007 No throttle miester, just the stock cruise control. I have completely backed it off to make sure it is not affecting it.
RFW Posted November 2, 2007 Posted November 2, 2007 BMW cables are designed to run dry. Exactly. The cables are teflon lined. All that oil will do is attract dirt and future problems.
90RedRider Posted November 2, 2007 Posted November 2, 2007 John I think the springs are just healthy. I noticed it on 1st long trip, having to hold throttle open all day. I got a throttle rocker for the cheap solution, so that the palm butt keeps pressure on without having to actively grip and apply continuous pressure.
