paulcbrowne Posted October 27, 2007 Posted October 27, 2007 I'm a bit frustrated that it seems to take 5 minutes for my accessories to shut off after turning off the ignition. Is this normal? Can the time be adjusted?
Firefight911 Posted October 27, 2007 Posted October 27, 2007 5 minutes seems quite long. Typical is between 30 - 90 seconds. I would make sure you have all your accessories shut off prior to turning off your key. If this fixes the problem, your accessories are "holding" the circuit open. What are you running through the accessory circuit? If the above resolves your problem wire direct to battery or, better yet, install a fuse block.
bobbybob Posted October 27, 2007 Posted October 27, 2007 My 07 owners manual states "approx. 15 minutes after switching off the ignition.....onboard socket is switched off...etc." However--mine sometimes stays on for several minutes, but other times may shut off in 1 minute or so. Seems unpredictable to me!
Ken H. Posted October 27, 2007 Posted October 27, 2007 Is this normal? Can the time be adjusted? Yes. No.
