Autocom Question
twilmotte
I'm thinking about buying an Autocom Super Pro AVi for my second bike, but I'm not sure how to interface it with my Baehr headset installed in my helmet that I use when I ride. The Baehr uses a 5-pin DIN connector and the Autocom uses a 7-pin connector (I thought). But when I looked at the "360 view" of the Autocom system on their website, it shows both a 7-pin and 5-pin DIN connector (http://www.autocomamerica.com/super_pro_avi.cfm). Does anyone have an Autocom with the 5-pin DIN connector? Does anyone know if it's possible to use a helmet with the (Baehr) 5-pin connector on an Autocom system? TIA confused.gif
You should contact Autocom USA. I don't know if an Autocom system can be interfaced with a Baehr headset. It's not the issue of the connectors. It's more the issue of the pinouts, the impedence differences, etc.
Call 888-851-4327 and ask for the Tech Desk. They'll be better able to answer your questions.
Rocket_Cowboy
The Autocom SuperPro AVI does use both a 5-pin as well as the 7-ping connectors. The 5-pin DIN connector is for the bike-to-bike radio interface ... including the Push-To-Talk adapter. The helmets (rider and passenger) use the two 7-pin DIN connectors.
Definitely check with Autocom America to see if they have an adapter for using your existing headsets with the Super Pro.
I believe Autocom makes a 7 to 5 pin adapter to allow the new 7 pin systems to work with the older Autocom 5 pin headsets but as Fernando says, the issue will be the pinouts. Check them
