rbstone Posted October 16, 2007 Share Posted October 16, 2007 New tool to remove the front wheel. Uses a 3/8" ratcht. The tool will fit into your tool kit. www.countryrode.com Link to comment
Jim VonBaden Posted October 19, 2007 Share Posted October 19, 2007 This multitool from Marc Parnes, a poster on this forum www.marcparnes.com is more versitile and is the same $25! Jim Link to comment
wkndman Posted October 19, 2007 Share Posted October 19, 2007 Or, just line up & tack weld two 9/16 nuts on a bolt, .59 cents at the surplus store.....cheers Link to comment
gettysburg Posted October 19, 2007 Share Posted October 19, 2007 Or, just line up & tack weld two 9/16 nuts on a bolt, .59 cents at the surplus store.....cheers Plus the price of welding equipment for those of us that don't already have some Link to comment
Dick_at_Lake_Tahoe_NV Posted October 19, 2007 Share Posted October 19, 2007 I went to my local Ace hardware store and bought the largest Metric bolt they have and two matching nuts. The head fits the front wheel perfectly. I then put the two nuts on the bolt and twisted them tight together. Works great and is small to fit in my tool kit on the bike. Link to comment
TrickLidz Posted October 20, 2007 Share Posted October 20, 2007 Or cut the hex end off a spark plug socket. Link to comment
maxfrankel Posted October 21, 2007 Share Posted October 21, 2007 Why would a rational person buy Parnes wheel removal tool or even bother to cut the head off a socket to create a front wheel removal tool? As has been repeatedly mentioned on this forum, a 45 cent bolt and two 5 cent nuts work perfectly! Link to comment
codinn Posted October 21, 2007 Share Posted October 21, 2007 Why would a rational person buy Parnes wheel removal tool or even bother to cut the head off a socket to create a front wheel removal tool? As has been repeatedly mentioned on this forum, a 45 cent bolt and two 5 cent nuts work perfectly! Why would a rational person introduce a concept like rational behavior into a gadget discussion on this forum ?? I use a 22mm nut welded to a 9/16" 3/8" drive socket. The local welding shop tacked them together for me for free !! BTW, I LOVE my Mark Parnes wheel balancer! Link to comment
maxfrankel Posted October 21, 2007 Share Posted October 21, 2007 Wheel balancer, yes! I own one as well. But a simple bolt won;t pass for a balancer, it will for a wheel removal "tooL"! Link to comment
Jim VonBaden Posted October 23, 2007 Share Posted October 23, 2007 Why would a rational person buy Parnes wheel removal tool or even bother to cut the head off a socket to create a front wheel removal tool? As has been repeatedly mentioned on this forum, a 45 cent bolt and two 5 cent nuts work perfectly! Because sometimes the right tool makes the job easier. I have the MP tool, and it works reliably and easily, as well as being light weight. I have tried double nutting a bolt, and had it slip on more than one occasion. I also have the cut off spark plug socket, and it works just fine, and was free. Why buy bolts and nuts, and the gas to go get them, and the time to go get them, when you can order one online for about the same amount? Or, make one from a socket you probably have lying around! Jim Link to comment
mrzoom Posted October 23, 2007 Share Posted October 23, 2007 Snap-on HXD22 works for me .lots of chrome on this baby!! Ok it costs $$ but remember I've got the biggest tool box on the planet 30' long and self propelled too Link to comment
TedG Posted October 23, 2007 Share Posted October 23, 2007 Motion Pro also makes a hex tool (17/19/22/24 combo), but it costs more than the Marc Parnes tool. Given that I already have a 19/24 tool for my rice grinder, I thought it would be nice to save a few bucks on the MP tool (compared to the Motion Pro) and support a BMWST member while I'm at it. As to using the suggested bolt/spark plug socket options, let's just say that I could screw up boiling water without written instructions... a tool maker I am not. Link to comment
maxfrankel Posted October 23, 2007 Share Posted October 23, 2007 Well Jim, let'see why. Option A: Buy a bolt and screw two nuts on it. Presto, you have a front wheel removal tool that works perfectly. Cost-trivial. Tools required to manuafacture - nil. Skill required to manufacture - niller still! Time to manufacture - nillest! And if you happen to be caught without it, well the "tool" is as close as your nearest hardware or Home Depot. Option B: Find the right size spark plug socket, cut the hex portion away, weld the hex to a ratchet extension. Cost - spark plug socket, ratchet extension, welding equipment. Tools required: vise, hack saw, welding equipment. Skill required to manufacture - welding. Time to manufacture - 45 minutes. Option C: Order Parnes tool. Cost: $25 plus shipping. Tools required: a pen, envelope and stamp OR a computer with internet connection. Skill required: writing or computer skills. Time required: Depends on former! ADDED ADVANTAGE- When you log on Parnes web site, you can read promotion for VonBaden's video! Oh, and Jim, surely double nutting a bolt so it won't slip requires less skill than that presumed in your maintenance video! Link to comment
Jim VonBaden Posted October 24, 2007 Share Posted October 24, 2007 Well Jim, let'see why. Option A: Buy a bolt and screw two nuts on it. Presto, you have a front wheel removal tool that works perfectly. Cost-trivial. Tools required to manuafacture - nil. Skill required to manufacture - niller still! Time to manufacture - nillest! And if you happen to be caught without it, well the "tool" is as close as your nearest hardware or Home Depot. Option B: Find the right size spark plug socket, cut the hex portion away, weld the hex to a ratchet extension. Cost - spark plug socket, ratchet extension, welding equipment. Tools required: vise, hack saw, welding equipment. Skill required to manufacture - welding. Time to manufacture - 45 minutes. Option C: Order Parnes tool. Cost: $25 plus shipping. Tools required: a pen, envelope and stamp OR a computer with internet connection. Skill required: writing or computer skills. Time required: Depends on former! ADDED ADVANTAGE- When you log on Parnes web site, you can read promotion for VonBaden's video! Oh, and Jim, surely double nutting a bolt so it won't slip requires less skill than that presumed in your maintenance video! Very funny. I suppose you make your own wrenches too? Some people would rather use the RIGHT tool, rather than risk messing up their expensive bikes with cobled together crap. But hey, have fun! Jim Link to comment
Thickasabrick Posted October 24, 2007 Share Posted October 24, 2007 There is another option. The tool kits from other BMW bikes or the extended tool kit for the R1200RT have some tools that will take out the axle. See the attached pic. Link to comment
maxfrankel Posted October 25, 2007 Share Posted October 25, 2007 Now come on Jim, get a sense of humor. When you have an untenable position, just admit it! And speaking of "cobbled together crap" as you describe it, doesn't your maintenance video illustrate the use of a "cobbled together crap" funnel/bolt for refilling the ABS pump? I actually found that cobbled together tool to reflect your resourcefulness, just as the double nutted bolt is a resourceful wheel removal solution. And I applaud your cross-marketing with Parnes, but a disclosure would be more forthright! Link to comment
Mike05 Posted October 25, 2007 Share Posted October 25, 2007 Why would a rational person buy Parnes wheel removal tool or even bother to cut the head off a socket to create a front wheel removal tool? As has been repeatedly mentioned on this forum, a 45 cent bolt and two 5 cent nuts work perfectly! Your choice to use a bolt & 2 nuts is just that; your choice. To present "your choice" by insinuating anyone who opts for an alternative other then yours is not rational is, at best, rude. There are a lot of reasons other then yours folks choose to do what they do; doesn't make them any more right or wrong then you. Just their choice. I bought (& use!) Jim's CD, I own more then one of Marc Parnes products & I'm happy with my choices. Still feel pretty rational too! Link to comment
maxfrankel Posted October 25, 2007 Share Posted October 25, 2007 "Some people would rather use the RIGHT tool, rather than risk messing up their expensive bikes with cobled together crap." Quote from Jim VonBaden Does this sound like questioning the rationality of someone's decision? Link to comment
ChrisJF Posted October 25, 2007 Share Posted October 25, 2007 Been away awhile dealing with various health issues - more or less back in one piece now, with newly acquired '05RT en-route . As my DIY skills are legendarily awful(*), I've bit the bullet and purchased both MP's wheel and his plugcap removal tools. To me, they're high quality, lightweight and a necessary addition to what passes for an RT toolkit these days. I've also just obtained the GS-911 diagnostic kit but that's another story! (*) I can't help thinking that if I tried to make a DIY wheelbolt tool by welding two bolts &c together, the resultant disaster over here would be front page news as well. The discussions in this thread also remind me about the sequence in "Zen and The Art Of Motorcycling" where one of the characters refuses to believe that such a sophisticated machine as a BMW motorcycle could be kept going by shims made out of a Coca-Cola tin ... Link to comment
Marty Hill Posted October 25, 2007 Share Posted October 25, 2007 The discussions in this thread also remind me about the sequence in "Zen and The Art Of Motorcycling" where one of the characters refuses to believe that such a sophisticated machine as a BMW motorcycle could be kept going by shims made out of a Coca-Cola tin ... They remind me of several 6 year olds saying...my daddy has a bigger car than yours. Very meaningful discussion! Link to comment
jaytee Posted October 25, 2007 Share Posted October 25, 2007 After reading this thread I decided to go with the Motion Pro Hex Axle Tool The additional sizes may prove valuable if a buddy on a different bike needs help as well. JT Link to comment
bakerzdosen Posted October 25, 2007 Share Posted October 25, 2007 After reading this thread I decided to go with the Motion Pro Hex Axle Tool The additional sizes may prove valuable if a buddy on a different bike needs help as well. That's what I use. Looks like we're both stupid for wasting $20 on a versatile tool. Link to comment
Joe_C Posted October 25, 2007 Share Posted October 25, 2007 $20.00? The link says it's $29.90. Where do I get the $9.90 rebate coupon? Link to comment
bakerzdosen Posted October 26, 2007 Share Posted October 26, 2007 $20.00? The link says it's $29.90. Where do I get the $9.90 rebate coupon? Dunno. That's just what I thought my local shop charged me. I might be mistaken, but still, I'm pretty sure it wasn't $30. Link to comment
Bullett Posted October 27, 2007 Share Posted October 27, 2007 We purchased an alleged "BMW shop tool" front wheel removal tool from our local independent shop for under $20. It looks like a 3" straight piece of hex tool (for lack of a better description) that you can put a wrench or a socket on. Link to comment
jaytee Posted October 27, 2007 Share Posted October 27, 2007 Just got the MotionPro tool... I chose to go with the CrMo tool instead of the aluminum - glad I did... rated to 150flb and not overly heavy, IMHO. It fits all three of my bikes, the 19mm for the warrior, the 22mm for the R1200ST, and the 24mm for the SV1000S. Mine was 35$ after tax and shipping - got it in one day - no kidding. As far as cost, $20, $30, $35 - whatever. I got a good quality tool that will always have a place in my tool box, especially since it works with lots of differnt bike's axles. JT Link to comment
shatzbot10 Posted October 27, 2007 Share Posted October 27, 2007 Just a Quick Question: Can the front wheel be removed while the R1200RT is on the center stand? It seems necessary to raise the front end slightly higher, to achieve clearance to slide the tire out (I'm thinking road side flat). Anyone? Thank you. Link to comment
bakerzdosen Posted October 28, 2007 Share Posted October 28, 2007 Just a Quick Question: Can the front wheel be removed while the R1200RT is on the center stand? It seems necessary to raise the front end slightly higher, to achieve clearance to slide the tire out (I'm thinking road side flat). Load up the back (pillion works fine) with weight, and you should be fine. You'll probably want to affix the center stand "just in case", but I've done it without. Link to comment
Jim VonBaden Posted November 2, 2007 Share Posted November 2, 2007 Now come on Jim, get a sense of humor. When you have an untenable position, just admit it! And speaking of "cobbled together crap" as you describe it, doesn't your maintenance video illustrate the use of a "cobbled together crap" funnel/bolt for refilling the ABS pump? I actually found that cobbled together tool to reflect your resourcefulness, just as the double nutted bolt is a resourceful wheel removal solution. And I applaud your cross-marketing with Parnes, but a disclosure would be more forthright! Yes, Mark sells my DVD's, I do not sell anything of his. I am also well known for using alternative tools and parts, but I do not use anything that can very possibly damage a bike, and two nuts on a bolt for removeing an expensive axle, possibly damaging the axle, and possibly slipping (as has happened in my experience) is not smart to me. If it works for you, great, have at it. I used the end of a 13/16" socket I cut off for quite some time and it worked fine. Marc's tool works better, and has more options, so I advocate it. I am not the only one who is a proponent of Marc's items, and do not benifit one cent from his sales. There is NO "cross marketing" going on here! I simply like his work, and appreciate the difficulties of selling to a crowd of owners famous for being cheap. This is why Marc does so well, and has a good reputation, because he sells quality at a very reasonable price. Now you can be sarcastic, and I couldn't care less, but you better have more than that if you want to impune my charactor. Jim HI Marty, you are everywhere lately! Link to comment
maxfrankel Posted November 4, 2007 Share Posted November 4, 2007 No attack on your character, just pointing out the fact that you promote a tool from a web site that promotes your video. Your suggestion that the head of a bolt that fits perfectly into the front wheel axle canal could damage the axle where the Parnes tool would not is beyond absurd. Even if the nuts slipped, that would in no way damage the axle. I guess when all is said and done, each of us has a special affection for our own tool!!!! Link to comment
Jim VonBaden Posted November 5, 2007 Share Posted November 5, 2007 No attack on your character, just pointing out the fact that you promote a tool from a web site that promotes your video. Your suggestion that the head of a bolt that fits perfectly into the front wheel axle canal could damage the axle where the Parnes tool would not is beyond absurd. Even if the nuts slipped, that would in no way damage the axle. I guess when all is said and done, each of us has a special affection for our own tool!!!! Link to comment
flyingreg Posted November 5, 2007 Share Posted November 5, 2007 Or, just line up & tack weld two 9/16 nuts on a bolt, .59 cents at the surplus store.....cheers Plus the price of welding equipment for those of us that don't already have some Come on now, you can get a muffler shop to tack weld that for a couple bucks, or for free. Go to this web page at http://www.r1200gs.info/misc/toolkit.html and scroll down the page for an example of this tool. Or, you can spend $$$$ for a tool that takes much more space. Space is more valuable in my bike tool kit. EDIT: Once again I should have read the entire thread before posting. You guys were doing quite well tearing up this thread without my help. Link to comment
maxfrankel Posted November 6, 2007 Share Posted November 6, 2007 I didn't mean to start WWIII by pointing out how well a plain old double nutted bolt works as a front axle removal tool. I am sure Parnes tool is a fine product. But for me, there are so many more desired farkles and specialty tools that I really need for my Beemer, as one who has to allocate my limited resources, I was delighted to learn that for a buck I could in 60 seconds assemble a perfectly workable front wheel removal tool. I only regret that some felt the need to raise absolutely absurd arguments to disparage this simple solution. Link to comment
Dick_at_Lake_Tahoe_NV Posted November 6, 2007 Share Posted November 6, 2007 Max, Way back on page 1 of this link you and I both suggested a "Double-nutted Bolt" as a small and simple tool to do this job. I went First Class and got a Stainless-steel Metric bolt and it fits perfectly. Also, I got it from my local Ace Hardware, so I didn't have to wait a week or so to have it delivered, when I needed it "right now". Certainly a quick, easy solution when a "Precision tool" is not needed. Link to comment
Bonkorama Posted November 6, 2007 Share Posted November 6, 2007 I just ordered the Marc Parnes tool and the JVB DVD set. I'm sure looking forward to getting them. Makin stuffs fun and cool, but i want the Marc Parnes Tool waaaaaaaaaaaahhhhh! Link to comment
maxfrankel Posted November 7, 2007 Share Posted November 7, 2007 And the bolt takes up less room in your tool kit Link to comment
