yechave Posted October 8, 2007 Share Posted October 8, 2007 The tiny bulb that lights under the headlight when the key is one position to the left of the steering lock position, is for what? I must have missed that in the manual. I saw this faint light after coming out from a meal, and was not sure if it was sunlight or what. Just having checked now that it is dark out, I see that both front and back lights are on....just curious what the purpose of using the lights are in that position? Thanks! Link to comment
Bprimm Posted October 9, 2007 Share Posted October 9, 2007 Visibility for short term parking Link to comment
Ken H. Posted October 9, 2007 Share Posted October 9, 2007 Not used to much in North America, but in other areas of the world it is more common to park a bike in places such as in a walking area with the lamps on. Link to comment
NoHeat Posted October 9, 2007 Share Posted October 9, 2007 It's a 5W bulb that I replaced with a 3W since it doesn't matter much anyway. IMHO it's useful for two purposes: 1. Keeping water out of the nose fairing. If you didn't have the bulb there, there would be a hole. 2. When you add an aftermarket accessory that requires a relay, you can tap into the parking lamp wire, and the relay will be activated only when the key is turned. Link to comment
MAT2CHI Posted October 9, 2007 Share Posted October 9, 2007 Say you ran out of gas or had another problem and you were stranded on the side of a narrow dark road, would you feel more comfortable with the parking lights on when you went to get help, or having your motorcycle sitting there in the dark. Link to comment
milesandmiles Posted October 9, 2007 Share Posted October 9, 2007 I use it for a headlight. No reason to give them any more warning than you have to. Link to comment
