Theophilus Posted October 7, 2007 Share Posted October 7, 2007 While doing the rear brake bleed a couple of weeks ago, we noted that my rear pads were thin. So yesterday, I picked up a pair of OEM pads and was all set to get into it today. I have a couple of questions, though: 1. The linings on the two pads are of noticeably different thickness; the right pad is 0.060" thicker than the left one. Is this normal? 2. The Haynes manual calls for a smear of copper grease on the back of the pads. How important is this? (read: how sorry will I be if I ignore this step?) I have no copper grease. Thanks! Link to comment
Stan Walker Posted October 7, 2007 Share Posted October 7, 2007 1) Yes. Since the rear caliper only has pistons on the right side that side will wear a bit faster than the left. 2) No problem, the BMW manual doesn't call for any copper grease to be applied. Stan Link to comment
Theophilus Posted October 7, 2007 Author Share Posted October 7, 2007 Thank you kindly, sir, for the timely advice. Off to the garage... Link to comment
ednowicki Posted October 8, 2007 Share Posted October 8, 2007 Check out this howto, it's pretty good. http://advwisdom.hogranch.com/Wisdom/BFDRear2.1.1.pdf Ed Link to comment
elkroeger Posted October 9, 2007 Share Posted October 9, 2007 So I suppose I'm the only one - but after noticing the asymetrical wear, I switched around my old brake pads (left to right, and right to left) figuring they'd even out by the time they were completely worn out. I can't think of a reason not to - anyone else? Link to comment
RTme2 Posted October 9, 2007 Share Posted October 9, 2007 I never even noticed that there was a difference in thickness. I've never used OEM pads, though. Dave Link to comment
Theophilus Posted October 10, 2007 Author Share Posted October 10, 2007 So I suppose I'm the only one - but after noticing the asymetrical wear, I switched around my old brake pads (left to right, and right to left) figuring they'd even out by the time they were completely worn out. I can't think of a reason not to - anyone else? Hmmmm... I cannot imagine how that would work. The pads on my bike are not made in such a way that you could do this... unless I am really missing something here... Link to comment
elkroeger Posted October 10, 2007 Share Posted October 10, 2007 Hmmm. indeed. Perhaps I'm a dope and just put them back the way I found them without realizing it? Although my pads are not exactly the same as those shown in the pdf posted above... (96 11rs). Link to comment
