power for autocom intercom system
calnative61
Posted
I just installed a Autocom Active Duo intercom system on my ,02 rt. The question I have is that the Autocom directions tells you to install the power lead to the first left blue fuse in the fuse box. I did that and it powered the system fine. But I noticed that the system was powered even with the key in the off position. There are 2 blue fuse in the fuse box, so I tried them both. With the same result. I'm not sure if the system powers down when not in use or is it a constant draw on the battery. Where can I get power, without the constant draw on the battery?
Thanks in advance.
p.s. I'm sure this has already been covered some where. Any help will be appreciated. cool.gif
Posted
I tapped in to the tail light (not the brake light). It only comes on when the bike is on.
Posted
Fuse #8 4amp is for am/fm radio and should work for you. Third in from other side ? Color may be pink to light red.
932828-fuseasst..txt
Posted
Thanks for the help. I'll try both suggestions
Posted
I believe that on the 1150, Autocom USA is suggesting Fuse #4, counting from the left when sitting astride the bike. To verify, give them a call at 888-851-4327. The AM/FM radio fuse will work, but that circuit is designed to stay on until you put your forks in the locked position, so be aware.
bigwilliejoe
Posted
I used the tail light power under the seat...keyed and works...now if I can get my Motorola bluetooth to work on the autocom!!!
Posted
My autocom turns itself off when I disconnect the headset cord---don't they all do this?
Posted
Only when they are running off a 9V battery. If they are hardwired into the bike, they are on when they have power and off when they don't. The headset has nothing to do with it.
Posted
That's good to know. I've been going under the assumption that as long as it's not plugged into the headset it's not on. dopeslap.gif
