NonComp Posted September 28, 2007 Share Posted September 28, 2007 Can you jump start an r1100 through the accessory cable? It's easier than lifting the tank to get at the battery, but do I risk burning out the wiring? Link to comment
AZBaldur Posted September 28, 2007 Share Posted September 28, 2007 No, I'm quite certain the accessory plug wiring can't handle the juice required to jumpstart. You will blow a fuse or burn wires very quickly. Recharge the battery instead, then start normally. Link to comment
UberXY Posted September 28, 2007 Share Posted September 28, 2007 I jumped my R11S directly on the positive terminal of the starter once. Getting to the battery was way too much of a hassle. Link to comment
NonComp Posted September 28, 2007 Author Share Posted September 28, 2007 Now that I've taken a moment to go back and look at it with the seat removed, I've discovered that it isn't a big deal to jump off the battery with the tank in place. The terminals are quite accessible. What I remembered was that battery removal required the tank to be lifted or removed. Edit: Well, I'm off to Penticton for the weekend. They're expecting snow at higher elevations. Should be a fun ride through the mountains -- a good shakedown cruise Link to comment
