R1200xx FD Failure Rate Poll. All R1200xx Owners Please Reply!
s3steve
R1200xx FD Failure Rate.
1,311 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
RightSpin has already done some of this.
It's a little dated. Feb. '05. Not enough info on the R1200xx at that point. I'm not interested in the older model FD failure rate. That's why I posted this in the Hexhead section.
I think you're making a mistake by not taking into account mileage and year of purchase data.
It would take a number of polls and questions to do that. Besides some people have said they have had a FD failure with a very low mileage bike.
This is just to get a general idea. It may help some people to make up there mind on a new BMW or maybe buy something else.
It may increase the FD hysteria or may relieve some peoples minds and just ride the darn thing!
Lets just see how it all turns out.
43,000 miles and counting with no failure. Right-side seal did develope a slow leak and was replaced around 35k under warranty. I have changed the oil my self twice. First time at 30k, second at 40k. First change oil was a bit cloudy with fine metal particles I think. Last change the oil looked as if it came straight out of the bottle. It was that clean.
Put 90,000 miles on my RT. No failure. Changed the FD oil with BMW Synthetic every 6K (takes 10 minutes, two 70-cent crush washers, and one-fourth of a quart of syn lube probably worth $5) and it was always clean.
Don_Eilenberger
Steve - great idea. If people want to tell more about their non-failure or failure - they can leave a message. The simplicity of the poll means you might actually get some data. I've forwarded the link to the IBMWR mailing list - where there has been a LOT of discussion and hand wringing over the two FD failures in the Iron Butt on Hexheads..
BTW - at 7,000 miles my R1200R drive seems just fine. Oil was changed as scheduled at around 450 miles (a tiny bit early 600 mile service - but I was leaving on a long trip..)
No FD failure yet (knocks on wood, crosses fingers and says silent prayer to the mechanical Gods), but I did have the gearbox seal problem. crazy.gif
Forgot to mention...06 RT with 30,000km
Jim
20,000kms (12,000 miles) and no problems here. My dealer didn't believe in the lifetime lube thing and changed the final drive oil on all R12 series bikes they sold at the initial 1000km service and then changes it again every 20,000kms thereafter.
Actually, it's updated to May 07. You will need to collect quite a bit more data to make your poll meaningful. Mileage, SN, type and date of failure will be necessary to correlate the results in a manner which will illustrate the problem. At best, I was able to only spot some vague patterns with about 100 failures reported.
There are simply not enough owners represented here to develop an accurate survey.
But thanks for the info!
Is this the complete data set up '07 you have?
http://www.rightspin.com/mc/misc/mpfs/mpfs.htm
I don't see any R1200xx in the report?
41K miles on my 1200GS. I changed the final drive fluid at about 36K miles and the old fluid looked just like the fresh, new stuff I put in. thumbsup.gif
I replied no failure. The outboard seal began to leak at 15K and was replaced under warranty, I consider that a failure.
For reference I replaced the FD fluid with Redline Shockproof at 1500 miles and have not touched it since nearing 18K. Many commuter as well as long, high speed miles on the clock.
One other observation, when I did the initial lube change there was no visible metal remnants in the fluid. I passed the original fluid through a filter at work and was amazed how "clean" it was. Others have noted quite a bit of debri during their first change leaving me to wonder about the assembly process and/or metal quality of their specific units.
As part of my normal work I perform failure analysis and investigation of these types of events, it sure would be nice to see BMWs analysis results. Without them we're all guessing as to causation.
32000km on my '05 R1200RT with no failure.
FD oil was changed at the 30000km service. The dealer tech. told me that although the oil change was not necessary it was probably a good idea...
I agree this poll is as good as the board facilities will support. I also agree that the survey as posted is more likely to be misleading than informative.
I had considered posting a poll but did not because I couldn't figure out how to structure it properly. Did not know about Rightspin's survey for the reasons he cites.
Although it will never be statistically valid, collecting data is not a bad thing. We need some real visibility for Rightspin's post, and to encourage everyone with a drive train failure to report to him regardless of model type. I would encourage an administrator to make Rightspin's thread sticky post in all four wrenching forums, if Rightspin is willing to handle all the reports he gets.
My FD failed at 38,000 kms (22,500 miles) on my '06 RT. Problem was not fluid or bearing-related. Splines on axle tube, and rotor flange, wore down creating significant play in rear wheel. From "no play" to "significant play" happened relatively quickly on a long road trip. Warranty repair; off road two days; parts/labour would have been $2000 USD said dealer. Invoice showed 9 1/2 hrs labour. Parts included final drive, rear rotor, and all lug nuts.
37K miles on my 12GS, and 23K miles on Tina's 12ST, NO failures.
I only know one guy out of about 40 who have had a 12 series FD failure. No idea of total miles, but likely 400K miles all in all.
Damn, I am absolutely certain I could do it in about an hour. Add another hour for diagnostics at most.
That's what I thought too, at the time. I assume this is what BMW allows and is what they would have reimbursed the dealer. The dealership (Salt Lake City) also told me the job was $2,000 in total. Once you deduct the cost of the FD, rotor, and lug nuts, that would seem to make the 9 1/2 hrs fit. All I know is that it was covered by warranty, thank god. This was not the first one of this type of failure that this dealer had repaired on an R12 bike. As I've pointed out before, this exact failure is the subject of a TSB for the R1200GS (probably because no other hexheads had been released for sale at the time the TSB originally came out).
Come-on folks...where are all of those failures??? Hmmm... we seem to be hovering at 3-5%, about what some older surveys has estimated.
Sheesh, 4%-5... I can live with that, espcially if it's likely to occur under warranty.
Your poll is being distorted (not that any internet poll can be trusted).
A link to it has been posted on other internet BMW groups (IBMWR for sure). That may suck in additional "failure" reports but is less likely to collect additional "good" FD reports.
So take this 4 percent number with an extra large grain of salt.
Stan
Rocket_Cowboy
2006 R1200RT. Purchased last Oct 31st. ~19,400 miles on the odo, impending final drive failure is in progress.
FD oil was changed at 12K and it's condition raised a good bit of concern from both the mechanic and the service manager. At 19K when I had tires mounted, the FD oil was changed again, looked even worse, and has metal in it. Service manager has a call into BMWNA to authorize FD replacement.
There is no outward sign of problems. There is no play in the rear wheel. There is no fluid leak on the FD. There is no grinding noise. But something is getting eaten up inside as evidenced by the metal shavings in the oil and overall poor condition of the FD oil when it's drained. The only reason I had them change the FD oil at the 12K service was because BMW had changed the lifetime "no-maintenance" claim on the final drives just before, so since it wasn't changed at 600 miles as they are now asking, I had it changed at the next available service.
Once we get the approval from BMWNA, we'll start disecting the FD to see what the culprit is.
Normally perhaps, but maybe not in this case. From what I've been reading on the Internet there seems to be just as much an axe to grind by those who want to prove there is no problem as those suggesting that there is.
Actually, 4 to 5% is at the high end of the range of estimates we've discussed in the threads in this board, although it is consistent with polling rates on advrider and bmwlt. If you are happy with that rate then thumbsup.gif.
Personally, if the number of premature FD failures is anywhere near that rate I'd be horrified. Consider, the last reported case, Linky FD on fire clearly shows that this is a safety issue, as if the evidence for that wasn't already clear! Imagine if that aluminum alloy metal had ignited?
Sorry to hear about your terminal FD.
How much metal are we talking about? Can you describe it for us--size, amount, was it suspended in the fluid, color? Thx.
I've noted a small amount of metal suspended in the used FD fluid from my R12RT during both fluid changes (9,800 miles and 21,000 miles) and considered it normal. I'd like to know what your mechanic views as normal versus abnormal.
Oh, yes....2005 R12RT purchased new March '06. No FD failure, or any other failure for that matter.
Definitely works both ways. Anyone with any statistical analysis skills and training would tell you that forum and basic internat polls are virtually useless.
Testimony is usefull in identifying the types of problems, but again, useless in determining how many or how often.
07 1200rt, on the 600 mile check - I was told the FD oil was changed. Is that new? It was not listed on my 600 mile "check" sheet in the owners' guide. I was told everything looked good - no issues.
Rocket_Cowboy
I didn't get specifics as to how much metal, but it was described to me as "chunky". I intend to get a better look at things once they start opening things up.
Rocket_Cowboy
Yeah, in 2007 BMW issued a tech bulletin now calling for the FD oil to be changed as part of the 600 mile service.
I feel MUCH better after seeing this poll, even though I know its statistically useless. Less than 5% failure rate seems acceptable. I would assume (but might be incorrect) that it skews to higher mileage units, althoguh a 7 unit sample is pretty small to be inferring that.
While 5% is not negligible, its also not the near-guaranteed horror that the boards make it out to be.
JT
No FD failure on a 1200GS bought new in April '04, now with 54,000km on the clock. Had the FD oil changed some time ago when they fixed the engine seal leaks.
No faillures on a R1200ST '05, did 37000 KM without any problems untill car ran it of the road. Bike is total loss since a few weeks. Ordered R1200RT last week.
