EddyQ Posted August 28, 2007 Share Posted August 28, 2007 I recently bought the BMW emblem (plaque) (51147667456) and the o-ring to replace the cheap looking black plastic cap just under the key on the triple tree. Now I have it and have no idea how to install it. The fiche make it look like the o-ring might hold it in the hole once the plastic cap is removed. Nope, the plaque and o-ring is far to small. The plaque is peal and stick. So maybe it is designed to simply stick to the old cap? But what is the o-ring for? Has anyone done this that could give me a clue? Link to comment
Volfan615 Posted August 28, 2007 Share Posted August 28, 2007 Did you get the stainless plug that goes in the hole where you remove the old plastic cap? The emblem then sticks into the stainless plug/cap. Link to comment
EddyQ Posted August 29, 2007 Author Share Posted August 29, 2007 Did you get the stainless plug that goes in the hole where you remove the old plastic cap? The emblem then sticks into the stainless plug/cap. I have no stainless piece. But, that sounds like it would work well. Attached is the fiche that shows the parts. I see no such stainless piece. Though, I will investigate. Link to comment
Volfan615 Posted August 30, 2007 Share Posted August 30, 2007 EddyQ I tried to reply to you private message but you aren't accepting them. Try this part.. http://www.ascycles.com/detail.aspx?ID=43429 You will need an emblem to go with this. Hope this helps. Link to comment
Willem_NL Posted October 28, 2007 Share Posted October 28, 2007 Hello there, Experienced the same as Eddy Q. It appeared that these items are replacements parts. Yesterday I received the correct item. It has a plastic base on which the badge is glued and it has the O-ring for keeping out moist. The partnumber is 31 42 7 704 591 and is originally used for the R1200R and S and some K's. In the Netherlands price was about 38 euro or about $ 50. Bye for now Link to comment
