Ben_Ricci Posted August 28, 2007 Share Posted August 28, 2007 The F800ST presents a few dimensional challenges for caliper mounting Motolights. After lots of trial-and-error engineering, here is what’s required for the F800ST caliper mount Motolight installation: (Motolight parts) 10-695 Caliper Mount Spacer Block Set 10x1.25x60mm socket head zinc plated 12.9 10mm lock washer The 10-695 spacer block has a 25mm offset and the stock BMW caliper bolt is 35mm, therefore a 60mm bolt is required. Please note that I did not use the lock washer because using it requires an additional 2-3mms bolt length (63mm?) to fully penetrate the caliper. I believe with proper torque, the clamping force should be sufficient. If you purchase a kit online, confirm it includes these parts. More pics: http://www.pbase.com/bricciphoto/motolights Link to comment
russell_bynum Posted August 28, 2007 Share Posted August 28, 2007 Glad you were able to get it sorted out! Link to comment
Firefight911 Posted August 28, 2007 Share Posted August 28, 2007 Glad you were able to get it sorted out! +1 to that! Now it looks as though I have to go shopping!!!!! Link to comment
Firefight911 Posted August 28, 2007 Share Posted August 28, 2007 Glad you were able to get it sorted out! +1 to that! Now it looks as though I have to go shopping!!!!! Yippie!!!!! Looks like another surprise for me!!! Link to comment
NoHeat Posted August 31, 2007 Share Posted August 31, 2007 Looks very nice| I think you might be a real pioneer, and it took some real persistence from you, too. I had checked for photos of F800 auxiliary light setups and I never found any. Until now. Congratulations! How well is the alternator handling the load? Link to comment
Ben_Ricci Posted August 31, 2007 Author Share Posted August 31, 2007 How well is the alternator handling the load? Good question. I'm not certain yet. It has been ridden since I installed them. The charging capacity is 400 watts. The lamps are 50W each. I think it should be okay as there is no other major loads (other than the headlight, which is 50 or 55 watts). We don't use electric jackets/pants. Link to comment
Firefight911 Posted November 2, 2007 Share Posted November 2, 2007 Still holding up? I am about to transplant the R12ST Motolights to Jamie's F800ST. Any other tips or corrections/adjustments now that you have some miles on them? Link to comment
Ben_Ricci Posted November 2, 2007 Author Share Posted November 2, 2007 Still holding up? I am about to transplant the R12ST Motolights to Jamie's F800ST. Any other tips or corrections/adjustments now that you have some miles on them? Yep. Holding up fine. My wife's been doing a lot of low rpm riding around, so I took it out last weekend (while mine was in the shop* )and ran it with Gerbings and didn't have any problems. I haven't put a voltmeter on it--maybe I'll do that while I'm re-farkling my bike this weekend. My only caveat: when mounted on the lower caliper bolt the Motolights are either the first or second thing to touch the ground in a tip over (toss up between Motolight and foot peg) as I discovered both times I dropped her bike. But I think the lights look better on the lower bolt. *new transmission seal and front brake rotors. Link to comment
bakerzdosen Posted November 2, 2007 Share Posted November 2, 2007 so I took it out last weekend (while mine was in the shop* )Sheesh... Talk about bad luck... Sorry man.(toss up between Motolight and foot peg) as I discovered both times I dropped her bike. But I think the lights look better on the lower bolt. note to self - don't let Ben borrow MY bike OK, I don't get it. Twice? An f800? Those things weigh like 3/5 the weight of your bike. Just bad luck? (I know I've probably just jinxed myself for even wondering, so I'll report back later today after I drop mine... ) Link to comment
Ben_Ricci Posted November 2, 2007 Author Share Posted November 2, 2007 Well, the first time I was on gravel and thought I had the side stand down, backed it up while standing next to it, then swung my leg over the back and kicked my camera case... and it started leaning, then more and more. The second time I was showing off and demonstrating to the wife how tight she could make a u-turn and just as I was in the midst of a full lock turn, I stalled it. No real damage and of course my wife thinks it's great because I've given up any opportunity to EVER say anything if she does the same thing. Link to comment
bakerzdosen Posted November 2, 2007 Share Posted November 2, 2007 No real damageWell that's the important part. I'm glad to hear that your wife took it well too. Link to comment
