jfremder Posted August 25, 2007 Share Posted August 25, 2007 I'm mounting up a brake disk on a spare wheel. The manual calls for Loctite™ 2701, but I can't find it anywhere...even at McMaster Carr Anyone else have a good substitute threadlocker for a small fastener in a high heat application? Link to comment
ShovelStrokeEd Posted August 25, 2007 Share Posted August 25, 2007 I believe Loctite 270 is the equivalent. Available here among others. Be careful with this stuff as it is a permanent bond requiring heat up to about 250 C to remove. The data sheets of the two products read pretty much the same. I think 2701 is just a European designation. I also saw a listing for A&S Cycles on the first page of a Google search so you might give them a call. Google IS your friend. Link to comment
smiller Posted August 25, 2007 Share Posted August 25, 2007 Be careful with this stuff as it is a permanent bond requiring heat up to about 250 C to remove.Yeah, this can be quite a PITA and I wouldn't use red unless it was really necessary... and I think that it tends to be over-specified by OEM manufacturers due to product liability concerns, etc. It's pretty rare to have any problems with a properly-torqued fastener and blue Loctite (243), and the medium-strength stuff is a lot easier to use and carries less risk of damaging parts. Certainly there are a few problem situations where red is required, but in my experience they're fairly infrequent. Link to comment
ShovelStrokeEd Posted August 25, 2007 Share Posted August 25, 2007 I fully agree. In fact, the 270 is the green stuff. REALLY tough bond. Link to comment
NonComp Posted August 25, 2007 Share Posted August 25, 2007 I you REALLY want the 2701 stuff, there is a BMW OEM part number for it on the Hammersley online parts fiche: 33 17 2 331 095 Link to comment
