Sailorlite Posted August 23, 2007 Share Posted August 23, 2007 HF is selling a "4 Piece End Cap" oil filter wrench set for $5 (p/n 94096). Does one of those caps fit the OE oilhead filter? If I had a spare filter, I'd check myself, but I don't. Link to comment
PapaJ Posted August 23, 2007 Share Posted August 23, 2007 I got away from the Bosch stock filter and use an Amsoil filter. It uses a more readily available size filter wrench, one of those four would probably work. Purolator, Wix, wal-mart, Mobile all make filters for the R1150RT that fit standard filter wrenches. Link to comment
Bob Palin Posted August 23, 2007 Share Posted August 23, 2007 The stock 1150 BMW filter is a standard, Fram type B, widely available at pretty much any auto parts store for a few bucks. Take a filter with you to make sure I remembered the right type! Link to comment
jfremder Posted August 24, 2007 Share Posted August 24, 2007 I have that HF set, and none fit the OEM Oilhead filter. A fram type B will, but you might have to turn down the outer diameter a bit to get it to fit in the recess Link to comment
Bob Palin Posted August 24, 2007 Share Posted August 24, 2007 I have that HF set, and none fit the OEM Oilhead filter. A fram type B will, but you might have to turn down the outer diameter a bit to get it to fit in the recess It fits just fine in mine. What bike won't it fit in? Link to comment
