pclarin Posted August 23, 2007 Share Posted August 23, 2007 Hi Gents: I bought a used topcase from one of our esteemed members along with a new lockset from Bob's. Any advice on removing the old lockset and installing the new? If anyone has the directions in paper form and would fax me a copy debt, I'll be in your debt! fax 305-295-8002 Help! Help! Help! paul Link to comment
Wooster Posted August 23, 2007 Share Posted August 23, 2007 Hi Paul, While there's absolutely no doubt this site rocks, rolls and rules, I suggest getting on ibmwr.org and looking in their "tech" files under "other". There you'll find a verbal description as well as a link to photos depicting the process. Wooster oh yes, I dispute the first step in the 'other' file yet agree completely with its link. That is, I don't think you "turn large nut counter clockwise" to remove locking cylinder; rather, it's just inserting small rod (straightened paper clip works) in tiny hole near key's slot while inserting/turning key and then pulling out key w/locking cylinder. Careful now, if you then remove key from cylinder (cylinder out of case) all the flat locking pieces are likely to shoot out in several directions ! Link to comment
pclarin Posted August 23, 2007 Author Share Posted August 23, 2007 Thanks much Jonathan. I just knew a description would be someplace to be found but after many searches came up empty. Thanks again! paul Link to comment
Mike_Brown Posted August 24, 2007 Share Posted August 24, 2007 You all are braver than I. I had the dealer do it for me.... I once saw all the little pieces flying around and it scared me. Mike Link to comment
pclarin Posted August 24, 2007 Author Share Posted August 24, 2007 Thanks to all who posted and pm'd me. I was making that job way more complicated than I needed to. In fact, after the wonderful advice, I had the job done and the case on the RT in under 10 minutes. Got that merit badge. paul Link to comment
