sideways Posted August 21, 2007 Share Posted August 21, 2007 Does anyone know if there is way to detach and reattach the little clear plastic flaps or wings or whatever they're called that lie under the windshield and are fixed to the top of the dash on the 12 RT? I just want to clean underneath them. I might try unscrewing the top of the dash, but thought maybe someone else might know an easier way. Did a search with no luck - I guess because I don't know what to call the little buggers. Thank you in advance! Link to comment
gettysburg Posted August 21, 2007 Share Posted August 21, 2007 They are each held in with a single phillips head screw. To reach the screws, you need to remove the front instrument panel; which also requires that the left and right fairings be removed. While you've got the panel removed, it would be a time to clean off the foam gasket surrounding the instrument cluster I've considered removing them completely to see if I could get more airflow behind the windscreen. Link to comment
Albert Posted August 21, 2007 Share Posted August 21, 2007 Wow that's a shame. For something that gets so dirty it seems that someone had their head up where the sun don't shine to design that. Link to comment
sideways Posted August 21, 2007 Author Share Posted August 21, 2007 They are each held in with a single phillips head screw. To reach the screws, you need to remove the front instrument panel; which also requires that the left and right fairings be removed. Good grief, Charlie Brown! Well, thanks very much for filling me in. I'll be out in the garage for about two weeks. Link to comment
Mike05 Posted August 21, 2007 Share Posted August 21, 2007 Mine stays dirty. Or, said another way, as clean as I can get them without removing anything. Muffler's shiny tho'. Link to comment
rogera Posted August 21, 2007 Share Posted August 21, 2007 I used a Q-tip once. Now there dirty all the time. Link to comment
AZRTRDR Posted August 21, 2007 Share Posted August 21, 2007 Riding in the rain helps. Link to comment
black99S Posted August 22, 2007 Share Posted August 22, 2007 cover them with speed (duct / gaffer) tape Link to comment
GordonB Posted August 22, 2007 Share Posted August 22, 2007 If you must.... Use a small paint brush when you are washing your bike, and let it drip dry or blow some air on it. It's not like you're looking thru it, or are you Link to comment
Twisties Posted August 22, 2007 Share Posted August 22, 2007 Mine were filthy when I got the bike new. Talk about a pmo. Link to comment
