mrduck Posted August 19, 2007 Share Posted August 19, 2007 Just did a TB check using a manometer and the bike is now very smooth BUT the idle is low (600 rpm)- so what's the best way to get it back up? Link to comment
bmwmick Posted August 19, 2007 Share Posted August 19, 2007 Just did a TB check using a manometer and the bike is now very smooth BUT the idle is low (600 rpm)- so what's the best way to get it back up? CCW on both big brass air-bleed screws. Mick Link to comment
Green RT Posted August 20, 2007 Share Posted August 20, 2007 Just did a TB check using a manometer and the bike is now very smooth BUT the idle is low (600 rpm)- so what's the best way to get it back up? CCW on both big brass air-bleed screws. In theory, if you turn both screws the same amount, your throttle balance won't be affected. In practice, I would want to adjust the idle with the manometer connected to confirm that the cylinders were balanced. Link to comment
