PRC Posted August 18, 2007 Share Posted August 18, 2007 Hope this is in the right forum, if not please move me to where I should be. My refurbed Garmin 2720 got here yesterday afternoon, and I am pumped. So this morning I go to install the drivers on my computer with the City Navigator NT v.8, and there's no data on the disk! Tried on both computers here at the house, the CD drive doesn't recognize there's a disk in the drive. WTH?? Any suggestions on what to do next? TIA. Link to comment
topdal46 Posted August 18, 2007 Share Posted August 18, 2007 turn the GPS on, and go ride with it, works well without a disc. Link to comment
Stan Walker Posted August 18, 2007 Share Posted August 18, 2007 It's not a CD. It's a DVD Stan Link to comment
bobbybob Posted August 18, 2007 Share Posted August 18, 2007 Hope this is in the right forum, if not please move me to where I should be. My refurbed Garmin 2720 got here yesterday afternoon, and I am pumped. So this morning I go to install the drivers on my computer with the City Navigator NT v.8, and there's no data on the disk! Tried on both computers here at the house, the CD drive doesn't recognize there's a disk in the drive. WTH?? Any suggestions on what to do next? TIA. Yep sounds like disk drive issue. If it IS a DVD it wont work if your drive is just for CD's. And if you have 2 drives like I have, and the disk is a CD, my DVD drive will not play CD's. Check compatibilities. Link to comment
PRC Posted August 18, 2007 Author Share Posted August 18, 2007 You guys are right (as usual) it's a DVD. So how do I get the drivers onto my computer if I don't have a DVD drive?? Link to comment
twilmotte Posted August 18, 2007 Share Posted August 18, 2007 Looks like you're going to have to install a DVD drive on your computer. The costs are way down (less than $50) for decent DVD read/write drives. Simple job, too ... just pull out the old CD drive and install the new one ... following the instructions, of course. Good luck. Link to comment
bobbybob Posted August 18, 2007 Share Posted August 18, 2007 Looks like you're going to have to install a DVD drive on your computer. The costs are way down (less than $50) for decent DVD read/write drives. Simple job, too ... just pull out the old CD drive and install the new one ... following the instructions, of course. Good luck. Looks like you're going to have to install a DVD drive on your computer. The costs are way down (less than $50) for decent DVD read/write drives. Simple job, too ... just pull out the old CD drive and install the new one ... following the instructions, of course. Good luck. Not necessarily--do you only have to install drivers? Or the entire City nav database? If its just drivers, if you have access to another computer that has a dvd drive you could just copy the files to the hard drive and then burn them to a CD or transfer to your comp. with a flash drive. Link to comment
PRC Posted August 18, 2007 Author Share Posted August 18, 2007 Not necessarily--do you only have to install drivers? Or the entire City nav database? If its just drivers, if you have access to another computer that has a dvd drive you could just copy the files to the hard drive and then burn them to a CD or transfer to your comp. with a flash drive. Yes, The GPS already is loaded with v8. I think I need the drivers so that I can download the updates when they come out. There's also a selection for extras in the menu..when I press this, it tells me to goto a website and d/l from there. Do I really need this though? As Vinnie Barbarino would say, "I'm so confused." Link to comment
RonStewart Posted August 18, 2007 Share Posted August 18, 2007 You can get a DVD drive for under $40 at your local computer store. I just went through this on Monday. Took longer to figure out how to open the computer case than to actually install and configure the drive. Link to comment
johnlt Posted August 18, 2007 Share Posted August 18, 2007 I'd recommend you install the full CN database on your hard drive so you can do your route planning on the PC with a mouse and big screen. It "can" be done on the GPS unit itself but it is much easier on a PC. Link to comment
decorbin Posted August 18, 2007 Share Posted August 18, 2007 You should be able to download the drivers from the Garmin site. Not sure, but you might be able to download the drivers and then upload the maps from the GPS itself. As others have already said, the DVD's are quite cheap now as well. Link to comment
