Jking Posted August 16, 2007 Share Posted August 16, 2007 How can you adjust the hieght of the brake lever and clutch lever on the 2007 R1200RT? I want to rotate them on the bars so the levers are facing down more. It looks like you can loosen the torx bolt and it would spin, but I'm not sure. Thanks Link to comment
bobbybob Posted August 16, 2007 Share Posted August 16, 2007 I *think* they are "pinned" into place but give it a try and let us know. Link to comment
AZRTRDR Posted August 16, 2007 Share Posted August 16, 2007 On my 05 I loosened the torx bolt inside the handlebar tube and used a rubber mallet to strike the reservoirs. This worked well but you must check the clearence. The tabs by the hoses had to be ground off of one side but I do not remember which side it was. A little adjustment goes a long way. Link to comment
99Roadster Posted August 16, 2007 Share Posted August 16, 2007 On the clutch side you need to pull the switch gear to expose the screw fastening the controls to the handlebar. A Phillips and a Torx screw from what I remember. I would imagine the brake side would be similar. Link to comment
