JimD Posted August 14, 2007 Share Posted August 14, 2007 Does anyone know of an off the shelf filter wrench that can be purchased locally & reasonably. Link to comment
butterbutt Posted August 14, 2007 Share Posted August 14, 2007 I use a strap wrench with great success. $3.99 at Autozone Link to comment
Spud99 Posted August 14, 2007 Share Posted August 14, 2007 I just punch a screwdriver through the old filter to remove and then hand tighten the new one. I discovered after purchasing a Jesse filter wrench that my hand tight is just about right on the torque specification from the manual. Link to comment
Jim VonBaden Posted August 14, 2007 Share Posted August 14, 2007 I just punch a screwdriver through the old filter to remove and then hand tighten the new one. I discovered after purchasing a Jesse filter wrench that my hand tight is just about right on the torque specification from the manual. So what do you do if you punch a hole in the filter, then can't get it off? Jim Link to comment
TEWKS Posted August 14, 2007 Share Posted August 14, 2007 Its not off the shelf but, its priced right. Shipping may make it less of a deal. http://www.motobins.co.uk/displayfinal.p...L+SERVICE+PARTS Pat Link to comment
Don_Eilenberger Posted August 14, 2007 Share Posted August 14, 2007 Not "off the shelf" - but price isn't bad and quality is great, plus you're supporting another BMW rider's business: http://www.beemerbalancers.com/oilfilterwrenches.php Found in only the finest BMW moto garages (mine..) Link to comment
SageRider Posted August 14, 2007 Share Posted August 14, 2007 I just punch a screwdriver through the old filter to remove and then hand tighten the new one. I discovered after purchasing a Jesse filter wrench that my hand tight is just about right on the torque specification from the manual. So what do you do if you punch a hole in the filter, then can't get it off? Jim Stop-n-Go ought to plug that right up! Link to comment
Spud99 Posted August 14, 2007 Share Posted August 14, 2007 I turn the bike upside down, get a big fricken' hammer and a cold chisel and get to work. Link to comment
Yankee_Dog Posted August 14, 2007 Share Posted August 14, 2007 Take your filter and head on down to thelocal auto zone. Try the filter wrenches on for size until you find one that fits. Yankee Dog Link to comment
Ken H. Posted August 14, 2007 Share Posted August 14, 2007 Remember too that the original oilhead filter sizes fit the hexheads just fine too. Easier to find both the filters and a wrench to fit them. Cheaper too. Link to comment
MickFinn Posted August 14, 2007 Share Posted August 14, 2007 This has to be a wind up ???? What's the date !!!! Link to comment
bakerzdosen Posted August 14, 2007 Share Posted August 14, 2007 I just punch a screwdriver through the old filter to remove and then hand tighten the new one. I discovered after purchasing a Jesse filter wrench that my hand tight is just about right on the torque specification from the manual. So what do you do if you punch a hole in the filter, then can't get it off? Jim Stop-n-Go ought to plug that right up! Or JB weld. Link to comment
Dave_in_TX Posted August 14, 2007 Share Posted August 14, 2007 Take your filter and head on down to thelocal auto zone. Try the filter wrenches on for size until you find one that fits. Yankee Dog I did that. None of them fit! Link to comment
keithb Posted August 15, 2007 Share Posted August 15, 2007 I just installed a new oil filter on Ruby with the longer filter that fits the 1100/1150/1100 K bike. The longer filter is quite easy to grab with my standard metal oil filter removal wrench. The first thing I did when installing this filter was to see if my filter wrench would fit and it did. And remember you only need to tighten the oil filter about 1/2 to 1 turn once the gasket touches. Link to comment
Blast54 Posted August 15, 2007 Share Posted August 15, 2007 I just installed a new oil filter on Ruby with the longer filter that fits the 1100/1150/1100 K bike. Gee...and I just bought six of the new type filters when I have six of the old (K1200RS) filters left Link to comment
keithb Posted August 15, 2007 Share Posted August 15, 2007 Bill Return the new ones if it is convenient. The older/longer filters work just fine. They hang down about 1/4" below the bottom of the engine which is NO big deal at all and you can find these filters at any auto parts store for a substantial savings vs. the new shorter model or the longer stock filters from BMW. Hang onto the ones you have and use them in the future. They don't go bad (hee hee). Link to comment
Ken H. Posted August 15, 2007 Share Posted August 15, 2007 I honestly don't understand why they switched to that dinky new filter size. Less filtering capacity, more expensive, harder to get on/off. Seems like a loose/loose all the way around. I can't see any downside to going back to the old filters on any of the hexheads. Link to comment
Spud99 Posted August 15, 2007 Share Posted August 15, 2007 This has to be a wind up ???? What's the date !!!! I plan on doing it the next time the screwdriver through the oil filter won't work. Link to comment
keithb Posted August 15, 2007 Share Posted August 15, 2007 Ken I bet BMW shortened it for weight reduction. You have to look at every piece of the bike in order to reduce the weight by 43 lbs. The shorter filter is half the weight of the original one. Makes sense to me. Link to comment
Ken H. Posted August 15, 2007 Share Posted August 15, 2007 Ken I bet BMW shortened it for weight reduction. You have to look at every piece of the bike in order to reduce the weight by 43 lbs. The shorter filter is half the weight of the original one. Makes sense to me. Well I'll give you that's the best explanation I've heard so far. Guess I'll just have to skip a couple of Big Mac's to compensate! Link to comment
Jim VonBaden Posted August 15, 2007 Share Posted August 15, 2007 I honestly don't understand why they switched to that dinky new filter size. Less filtering capacity, more expensive, harder to get on/off. Seems like a loose/loose all the way around. I can't see any downside to going back to the old filters on any of the hexheads. Just curious Ken, has anyone confirmed the filtering and relief valves are the same on both filters? Just because it fits, doesn't mean it should be there. Jim PS I know several people who use the old filters, or alternates, with no issues. Link to comment
Paul Mihalka Posted August 15, 2007 Share Posted August 15, 2007 I don't think BMW likes the idea of the oil filter hanging out of the crankcase and be the lowest point under the engine. I consider the old style filter on a hexhead acceptable only on a GS with the bash-plate protecting it. Link to comment
Albert Posted August 15, 2007 Share Posted August 15, 2007 Just curious Ken, has anyone confirmed the filtering and relief valves are the same on both filters? Just because it fits, doesn't mean it should be there. I was wondering the same thing Jim. There's more to a filter than just a can with an element inside. Have they changed the specs on the oil pumping pressure or capacity? As Jim said there's usually a by-pass capability in a filter as well. I'd want to know the differences other than dimensions for sure before risking my 20k investment for a couple of bucks. Link to comment
Ken H. Posted August 16, 2007 Share Posted August 16, 2007 Just curious Ken, has anyone confirmed the filtering and relief valves are the same on both filters? I'm not aware of any. I'm just going by the experience of a number of people who are using the older filters with no issues. For that matter there are so many different ones being used on the oilheads they probably don't have the same relief valve in particular specifications either. Link to comment
Jim VonBaden Posted August 16, 2007 Share Posted August 16, 2007 Just curious Ken, has anyone confirmed the filtering and relief valves are the same on both filters? I'm not aware of any. I'm just going by the experience of a number of people who are using the older filters with no issues. For that matter there are so many different ones being used on the oilheads they probably don't have the same relief valve in particular specifications either. Same here, just wondering. I am past warranty on my bike, so I will use whatever I can find for a reasonable price, but if you are in warranty, you might want to be a little more descriminating. Thanks, Jim Link to comment
SteveNY Posted August 19, 2007 Share Posted August 19, 2007 A longer filter might be OK in a pinch, but consider that the stock filter is exposed and can get punctured if you bottom out on a rock. Ask me how I know... A longer filter would be even more vulnerable. Steve Link to comment
Ken H. Posted August 20, 2007 Share Posted August 20, 2007 A longer filter might be OK in a pinch, but consider that the stock filter is exposed and can get punctured if you bottom out on a rock. Ask me how I know... A longer filter would be even more vulnerable. True, I use the original oilhead length filter, but I should point out that I'm strictly a street rider. If I went over something big enough to get the filter, I've got bigger problems than the filter! Link to comment
