Solidrick Posted August 13, 2007 Share Posted August 13, 2007 I am having a few drops on oil drip on my rear wheel when I ride, and a clean drop of oil form on the drain plug of the final drive a while after a ride. I have torqued the drain plug and it still leaks. I will change the oil again and replace the crush washer and see what happens. Any suggestions from the collective? Rick Link to comment
Ken H. Posted August 13, 2007 Share Posted August 13, 2007 If it's coming from around the plug, a new crush washer will usually fix it right up! Link to comment
Davis Posted August 13, 2007 Share Posted August 13, 2007 Also make sure there aren't two crush washers on there. Link to comment
ESokoloff Posted August 13, 2007 Share Posted August 13, 2007 All bad advice I'm afraid Rick. What you really need is some JB Weld Link to comment
GordonB Posted August 13, 2007 Share Posted August 13, 2007 Any chance you're oferfilled and it's coming from the vent, and dribbling down to the plug on the back side? Link to comment
Ken H. Posted August 13, 2007 Share Posted August 13, 2007 What you really need is some JB Weld Cruel, that's just plain cruel! Link to comment
