Yeti Posted August 13, 2007 Share Posted August 13, 2007 I have a 95 R1100R and I've taken the tank off to strip it and paint it. I was able to get most of the gas to drain out through the fuel lines but there's still a fair amount of gas in there. Anyone know how to get the rest of the gas out? I tried siphoning it but it seems the gas is in a part of the tank where I can't get the siphon to go to. Link to comment
Stan Walker Posted August 13, 2007 Share Posted August 13, 2007 aaah.... how about opening the cap and turning the tank upside down? Then dry it out with compressed air, for a day or two. Stan Link to comment
Yeti Posted August 13, 2007 Author Share Posted August 13, 2007 Hmmmn, I'll try it. But isn't there a filler neck that would prevent this? Link to comment
Stan Walker Posted August 13, 2007 Share Posted August 13, 2007 But isn't there a filler neck that would prevent this OKOK, that's what I get for trying to be a smart A$$. This time for real. Really. Honest injun (or is that honest engine?) There should be a fuel pump access plate on the inside of the tank. This is a plate with a wire cable and two fuel lines plus two vent lines coming through it. Remove it. This is a great chance to change your fuel filter. You will have to deal with couple of vent lines on the inside that need to be disconnected. That will leave a big hole from which you can pour out fuel, reach inside and wipe dry, etc. Stan Link to comment
Yeti Posted August 13, 2007 Author Share Posted August 13, 2007 I guess I may have to do that. The fuel filter was just changed about 2k miles ago so I didn't want to open the tank back up but I may have to. I'm going to try a couple of ideas and if they don't work I'll open her back up. Link to comment
Bill_Walker Posted August 13, 2007 Share Posted August 13, 2007 I guess I may have to do that. The fuel filter was just changed about 2k miles ago so I didn't want to open the tank back up but I may have to. I'm going to try a couple of ideas and if they don't work I'll open her back up. If you don't want to change the filter, then you don't have to pull the whole assembly out, I'm thinking. Just loosen up the bolts, separate it from the tank, and support the tank in a way that doesn't put any weight on the filter/pump assembly to let it drain (which might be the hard part). Link to comment
Utard Posted August 13, 2007 Share Posted August 13, 2007 If you do end up completely removing the plate, make sure you mark the vent tubes so they don't get mixed up. I'm told that if this happens, the bike won't run worth poop and it's very hard to fix. Link to comment
Yeti Posted August 14, 2007 Author Share Posted August 14, 2007 If you do end up completely removing the plate, make sure you mark the vent tubes so they don't get mixed up. I'm told that if this happens, the bike won't run worth poop and it's very hard to fix. Thanks I did make sure to mark the lines before I took them off so I'm good there. Link to comment
