Rob L Posted July 27, 2007 Share Posted July 27, 2007 Valve covers, brake calipers, wheel fasteners, and steering/suspension fasteners get the torque treatment on my bike. Peace of mind is worth a few minutes of time and stripped fasteners can get expensive. Link to comment
T__ Posted July 27, 2007 Share Posted July 27, 2007 Jeff, you forgot one option_____ None of the above.. Twisty Link to comment
Jim VonBaden Posted July 27, 2007 Share Posted July 27, 2007 Wheel bolts, head bolts, and any critical suspension parts is about all I torque. Jim PS That doesn't mean I am not aware of the proper torque values so I can avoid over tightening a bolt. Link to comment
Yankee_Dog Posted July 27, 2007 Share Posted July 27, 2007 dont forget oil plugs and such. Yankee dog Link to comment
Bob Palin Posted July 27, 2007 Share Posted July 27, 2007 I'm in between "whenever possible" and "only critical", I torque things that are vital like lug nuts and brake components and things that I might screw up like the valve cover bolts. I don't bother with the screws in the fairing or the oil filter. Link to comment
ShovelStrokeEd Posted July 27, 2007 Share Posted July 27, 2007 Cylinder stud nuts, axle/lug bolts, brake caliper fixing screws and damn little else. I can feel spark plug washers and oil drain crush washers doing their thing, ditto rocker cover bolts. They make wrenches in various lengths for a reason. Link to comment
11101110 Posted July 27, 2007 Share Posted July 27, 2007 I use torque wrenches calibrated to NIST traceable standard. Of course when you have a torque calibrator at your disposal, why not. Link to comment
USAF1 Posted July 27, 2007 Share Posted July 27, 2007 Hmmmmmmmmm, where's the guy who had the story about stripping out/cracking his valve cover bolts??? Pat Link to comment
Woodie Posted July 27, 2007 Share Posted July 27, 2007 Hmmmmmmmmm, where's the guy who had the story about stripping out/cracking his valve cover bolts??? Uhh...which one? Link to comment
RFW Posted July 27, 2007 Share Posted July 27, 2007 I use a torque wrench on fasteners that are critical. After 45 years of working on engines, I have my own built-in "torque wrench" that is sufficiently accurate for less critical items such as case bolts, oil drain bolts, spark plugs, and so on, that are not particularly sensitive to exact torque. In many cases, it isn't even the VALUE of torque that matters much, but rather only that the torque is the same among a related series of bolts. Link to comment
Stan Walker Posted July 27, 2007 Share Posted July 27, 2007 It's a guy thing, real men don't use torque wrenches....... Stan Link to comment
philbytx Posted July 27, 2007 Share Posted July 27, 2007 quote I don't bother with the oil filter unquote You lazy old Git Link to comment
smiller Posted July 27, 2007 Share Posted July 27, 2007 Hmmmmmmmmm, where's the guy who had the story about stripping out/cracking his valve cover bolts?? I once stripped out a valve cover bolt because I was using a torque wrench! Accidentally set it to 18 nm instead of 8. If I had been tightening by feel I never would have applied enough force to strip it... so torque wrenches aren't always a good thing! Seriously, an experienced mechanic can do pretty well without a torque wrench. I'll bet the guy you pay to work on your bike only uses a torque wrench for critical fasteners (if that.) Link to comment
Wooster Posted July 27, 2007 Share Posted July 27, 2007 ...I once stripped out a valve cover bolt because I was using a torque wrench! Accidentally set it to 18 nm instead of 8. If I had been tightening by feel I never would have applied enough force to strip it... so torque wrenches aren't always a good thing!... I voted 'whenever posible" yet recognize the dilemma; using a 14 inch long torque wrench to tighten a small fastener requires giving up most of the perception of force applied via appropriate sized wrench (say, 6 inches). Just the same, if a credible source lists torque value, I'll use it (the value and torque wrench). Wooster with three torque wrenches "old mufflers never die, they just get exhausted" btw Smiller, in your example cited here , it wasn't the torque wrench's fault that some one set 18 nm instead of 8 Link to comment
Baba_ORiley Posted July 28, 2007 Share Posted July 28, 2007 Oh, so I get it. The question is not whether to torque or not because tightening involves torque, but whether to accurately measure the torque applied and match that measurement to specs. Answer: Yes. It adds peace of mind. Link to comment
AviP Posted July 28, 2007 Share Posted July 28, 2007 I use my torque wrench whenever any bolt has a torque spec mentioned in the manual. To the average mechanic, hand tightening results in way more torque than the spec.. There was a time when I never used a torque wrench and never had anything fail on me either. I just decided to get fancy one day. Link to comment
Byrdguy Posted July 29, 2007 Share Posted July 29, 2007 I don't torque much of anything, unless I'm building an engine, head bolts, rod and crank, etc. I've ben wrenching for over 45 years am "old school", I guess. I can feel how much to tighten a fastener without stripping. Link to comment
Silver Surfer/AKAButters Posted July 29, 2007 Share Posted July 29, 2007 I'm with Bob and some others. I don't torque the fairing screws and such. Link to comment
AviP Posted July 29, 2007 Share Posted July 29, 2007 I'm with Bob and some others. I don't torque the fairing screws and such. Torque the fairing screws!!! Link to comment
notacop Posted July 29, 2007 Share Posted July 29, 2007 1+++. Maybe on something like swing arm pivot bolts at 80-90#. all others are by feel. From the sad tales posted about over torqued fasteners, folks need to be more practiced. Link to comment
