speedi Posted July 24, 2007 Share Posted July 24, 2007 I have a pair of Joe Rocket waterproof street cycle boots with leather uppers and a rubber type bottom. The bottom is separating from the boot. What can I use to glue or seal the bottom back on?? Has anyone had this experience? Thanks! Link to comment
Jerry Johnston Posted July 24, 2007 Share Posted July 24, 2007 I'd try Shoe-Goo. I used to use Shoegoo on my tennis shoes and it filled in the worn spots and would last for several months. I have an old pair of Joe Rocket bootss that are still ok just not my favorite any more - never did seperate. Link to comment
keithb Posted July 24, 2007 Share Posted July 24, 2007 Go to Home Depot/Lowe's/hardware store. Get a dual syringe of Epoxy. Express out both components mix them together and apply to the sole of your boot. I would put some clamps on it to hold it together. I bought a pair or work boots from Sears 5/6 years ago and the sole is doing the same thing. All it takes is a few bucks and some of your time to do it. Easy fix really. Link to comment
Wyn Posted July 24, 2007 Share Posted July 24, 2007 I had a pair of Muc boots that I used when I pressure washed concrete. At that time I didn't use hot water. I used pool chlorine to kill the mildew. The soles seperated so I took them to a koobler and he glued them back together. I don't know what he used but it worked. Finally trashed them after the soles completly wore out down to the glue. Link to comment
Wyn Posted July 24, 2007 Share Posted July 24, 2007 I had a pair of Muc boots that I used when I pressure washed concrete. At that time I didn't use hot water. I used pool chlorine to kill the mildew. The soles seperated so I took them to a koobler and he glued them back together. I don't know what he used but it worked. Finally trashed them after the soles completly wore out down to the glue. Koobler??? Oh man, it sucks gittin old!! Link to comment
