External Hex for front wheel removal
New1200RTRider
New1200RTRider
Hey Guys, where is the best place to buy the 22mm external hex tool to remove the front wheel axle?
thanks
I think the BMW spark plug socket tube fits the front wheel axel????Two tools in one,wheel and spark plugs thumbsup.gifI think i got mine from one of my K1200LT,s,It must of fallen out of the tool kit before I traded it in lmao.gif
Firefight911
You are correct, it does!! The tool has a white piece of plastic around it.
Almost went and bought something until I realized that I already had the tool!!! dopeslap.gif
Jim VonBaden
Just cut the top off a 13/16" spark plug socket like I did. The cheap Taiwan ones seem to fit best, and cut easily. I have used this on dozens of tire changes.
Or leave it on and fit an extension through the axle:
That is, IF it wont fit in backwards.
Dick_at_Lake_Tahoe_NV
I went down to my local Ace hardware store and bought the largest Metric Bolt they have. The head fits neatly into the front axle socket. Then I bought two nuts and locked them together onto the bolt--works great. clap.gif
A 3/4-10 heavy hex nut works well (7/8 across flats). Run it on a 3/4-10 screw with a 3/4 flat washer between the nut and the head of the screw with locktite and torque it to about 80 ft-lb. The nut fits in the axle hole and you use the bolt head to unscrew the axle. You might have to file the sharp corners off the nut. Try in in the axle hole before you run in on the screw.
Thanks Jim VB for the creative way of using the plug wrench; through the axle if necessary....
I bought one of these "shower" wrenches from a local hardware....21/32 on one end fits...Less than 2 bucks I think......
Phil......Redbrick
