SHOman Posted July 21, 2007 Share Posted July 21, 2007 hello, Typing this with oily fingers... I am performing my 18k service valve adjustment (1st time). I read the "how to's" and have the TDC mark in what I think is center of the viewing hole. Valves are able to be wiggled. What angle should i be looking at the hole? dead on, eyes at same level? I want to be sure I am looking from the correct angle. Also, I unscrewed the head bolts by hand. Should they have been this loose? THANKS! back to them valves for a bit. Link to comment
Stan Walker Posted July 21, 2007 Share Posted July 21, 2007 Also, I unscrewed the head bolts by hand. Should they have been this loose? I assume you mean valve cover bolts...... No, they should have been torqued to 8 Nm. If you really meant head bolts you have a serious problem. What angle should i be looking at the hole? dead on, eyes at same level? I want to be sure I am looking from the correct angle It doesn't matter. There is a large area of the cam opposite the cam lobe where there will be no up or down motion of the cam follower. I would say "flat" but of course the cam is really round. Stan Link to comment
SHOman Posted July 21, 2007 Author Share Posted July 21, 2007 Thanks for the quick reply Stan, yes i meant the head cover bolts. I was really suprised how lose they were, no even finger tight. Link to comment
Stan Walker Posted July 21, 2007 Share Posted July 21, 2007 I was really suprised how lose they were, no even finger tight. Some one goofed. I'm surprised you didn't notice an oil leak. Stan Link to comment
