ScooterCop Posted July 20, 2007 Share Posted July 20, 2007 This past week, I had the front calipers off to remove the front wheel. When reinstalling the calipers I got them onto the rotors and pressed the pistons in. But now the brakes pads are constantly rubbing on the rotors, even slowing the previously free spinning wheel. Will this sort itself out? Should I be worried? Anything I can do to remedy the situation? Link to comment
Tipover_Bob Posted July 20, 2007 Share Posted July 20, 2007 This past week, I had the front calipers off to remove the front wheel. When reinstalling the calipers I got them onto the rotors and pressed the pistons in. But now the brakes pads are constantly rubbing on the rotors, even slowing the previously free spinning wheel. Will this sort itself out? Should I be worried? Anything I can do to remedy the situation? Scooter: You got me worried big guy. I just had my front wheel off to replace the front tire and the brakes are just exactly like they were before after a couple of pumps on the lever. Are you very sure you got the disk back between the pads? You can tell by looking at the top of the calipers. There should be about 1/4 inch space between the tops of the pads. Other than that everything should quickly resume the status as before removal. If you accidently jammed the disk behind a pad, and it would probably go there if you forced it, it would drag and it would probably ruin the disk very quickly. Tipover Bob Link to comment
ScooterCop Posted July 21, 2007 Author Share Posted July 21, 2007 No, I knew enough to check that way before I even so much as rotated the wheel. Link to comment
arbee Posted July 21, 2007 Share Posted July 21, 2007 Is ABS fitted? This was my symptom before the ABS pierced my front & rear brake hose by applying pressure at all times Link to comment
Ken H. Posted July 21, 2007 Share Posted July 21, 2007 Depends upon how much rubbing you're talking about. Some drag is normal on all disk brakes. If it's enough that it's heating the rotor, that's an issue. Unfortunately it'd hard to quantify here. Is there another similar bike you can get to to compare to yours? Link to comment
