04RT - Rear Pad replacement
otis
Is there anything special and/or to be concerned about when replacing the rear brake pads on a 04 RT?
Or…just the usual, pull caliper and pads, use C-clamp to push piston back in caliper…..reverse for assembly.
And...doe modt of you have the rear pads wear out before the front?
Thanks,
Pat
Nope, and you don't need a c-clamp.... remove the caliper, using a lever, depress the pads, slip the pin and remove the old pads, than insert new pads and pin. Reinstall the caliper. Done
I was amazed how stright forward it was.
And...doe modt of you have the rear pads wear out before the front?Pat
Yes on my particular R1150RT, the rear pads wear out MUCH more quickly than on the front.
Andy
