amsoil
beagle
duckbubbles
It's not a V-twin, is it?
Now use a little brain- if it meets or exceeds the manufacturers recommendations, it's ok. I've used it in the past.
Frank
most positively! the beemer is air cooled just like the hardley. i use the mobil 1 M/C equivalent, couldnt be happier.
I have a case of amsoil 20w50 v twin oil. do you think it is ok to use on an 1150?
I wouldn't chance it..I'll take it off your hands for $10.00 and I'll pay shipping.. smirk.gif
I'll give you $15 and pay shipping
Beagle, actually that is a very good oil for air/oil cooled motorcycles.. Very good resistance to high heat, good anti wear additives, great engine storage additives..
Down side___ On the samples I have had tested the viscosity runs to the higher side of specs (I think the newest V-Twin Amsoil is slightly different) so extreme cold start cold ride away probably isn’t it’s strong suit.. I run that oil myself & do ride in weather that can get as low as 0°f so modulate my cold ride off habits a little in below freezing weather..
I see you live in my area so if you ride extreme cold weather keep that in mind..
Twisty
I just put in the last of my Amsoil 20W50 (bought a case) into my R1150R. I'll take that off your hands.
P
