s3steve Posted July 11, 2007 Share Posted July 11, 2007 I was the Sportbike Rally in Parry Sound, Ontario on the weekend and found it to be a bit of a hassle carrying around my helmet all weekend. Does anybody know what the part # is for the helmet security cable? Cost? Thanks!! Link to comment
pbbeck Posted July 11, 2007 Share Posted July 11, 2007 I'm pretty sure you can find a steel cable at the local hardware store or DIY store for a fraction of the cost. I did. Link to comment
Fugu Posted July 11, 2007 Share Posted July 11, 2007 I made myself one out of vinyl coated aircraft cable and fittings from the hardware store for about $5. I'm not sure the specific cable you are referring to needing a part# for, but I just made a cable with a loop at each end - works great on a bike helmet lock, or with a pad lock, or with my longer cable bike lock looped through it. Link to comment
Dick_at_Lake_Tahoe_NV Posted July 11, 2007 Share Posted July 11, 2007 So go to Home Depot and buy 3-feet of plastic covered 1/8" cable. Then buy a package labled: 1/8" Ferrule and Stop Set. That gives you material to swage the cable ends to make a loop. Assemble in a couple of minutes and it works great. Link to comment
LANGeek Posted July 11, 2007 Share Posted July 11, 2007 If you can't or don't want to make one here is one for 10 bucks. http://www.bmwsantacruz.com/Merchant2/me...roduct_Count=53 Personnally, I made mine. Link to comment
Tapatio Posted July 11, 2007 Share Posted July 11, 2007 I bought this solution which works nicely and doesn't require pulling the seat off. Not quite as secure as a cable but good enough for my needs. $42 at A&S Helmet Lock Guarian Link to comment
Tapatio Posted July 11, 2007 Share Posted July 11, 2007 Or this one (actually the one I bought). Z Technik Link to comment
Beemeroil Posted July 11, 2007 Share Posted July 11, 2007 Why not use helmet cable under the seat. Use a longer one so you can also run it throught the arm of your jacket. Link to comment
F_Magna Posted July 11, 2007 Share Posted July 11, 2007 Mr BMW part 46 63 2 347 287 - It doesn't look the most resistant, but would stop that 'impulse theft' Fits to the pegs under the seat Link to comment
