Bob Palin Posted July 7, 2007 Share Posted July 7, 2007 Just helped a visitor get a flat fixed, took his rear wheel off and there was no spacer - is that just an RT thing or was his missing? Link to comment
duckbubbles Posted July 7, 2007 Share Posted July 7, 2007 Real OEM says yes, with integral anti lock brakes. I guess not, without. Frank Link to comment
Ken H. Posted July 8, 2007 Share Posted July 8, 2007 Missing. All the R1150xx series are suppose to have it. Link to comment
Paul Mihalka Posted July 8, 2007 Share Posted July 8, 2007 Odd. The R1150 has the brake disk mounted to the wheel, not to the rear drive like the R1100. I would think leaving the spacer shim out would cause serious disk to caliper mis-alignment. Link to comment
Stan Walker Posted July 8, 2007 Share Posted July 8, 2007 Odd. The R1150 has the brake disk mounted to the wheel, not to the rear drive like the R1100. I would think leaving the spacer shim out would cause serious disk to caliper mis-alignment. Floating caliper in the rear will adjust to disk position. It's the ABS sensor that prevents removing the spacer. I guess it could be adjusted but unless you do so it rubs. Stan Link to comment
Mark K Posted July 9, 2007 Share Posted July 9, 2007 Weren't some folks removing those and claiming a cure to PTTR? Link to comment
smiller Posted July 9, 2007 Share Posted July 9, 2007 Weren't some folks removing those and claiming a cure to PTTR? Only on the 1100, not 1150, for the above-mentioned reason. Link to comment
silverhornet Posted July 11, 2007 Share Posted July 11, 2007 Only ABS models have the spacer ring fitted. Link to comment
Mark K Posted July 12, 2007 Share Posted July 12, 2007 Weren't some folks removing those and claiming a cure to PTTR? Only on the 1100, not 1150, for the above-mentioned reason. Duh That makes sense. I should have thought about that before advertising my ignorance. Link to comment
bmwmick Posted July 12, 2007 Share Posted July 12, 2007 Only ABS models have the spacer ring fitted. ALL cast wheels should have the spacer installed. ABS/non-ABS makes no difference. Mick Link to comment
silverhornet Posted July 14, 2007 Share Posted July 14, 2007 Only ABS models have the spacer ring fitted. ALL cast wheels should have the spacer installed. ABS/non-ABS makes no difference. Mick [/quote My R1150RS ABS has one..............My R1150 Rockster non ABS does not Both owned from new Link to comment
