Moosedog Posted July 7, 2007 Share Posted July 7, 2007 Does anyone know (silly question on here, I know) how to adjust the shift lever so it is a bit higher and easier to get a motorcycle boot under it without having to dislocate my ankle? Link to comment
tbarstow Posted July 7, 2007 Share Posted July 7, 2007 If the linkage looks like the one on my LT, you need to disassemble the shift linkage (those little pins are neat fasteners), move the jam nuts in,screw the ball joints down a bit further. The hard part is getting it all to miraculously fit back together and line up properly. Not fun at all. In the end, its probably easier to take the belt sander and make your foot thinner. Link to comment
tallman Posted July 8, 2007 Share Posted July 8, 2007 Are your pegs in the lower position? Link to comment
NoLongeraK1200RSRider Posted July 9, 2007 Share Posted July 9, 2007 Now why on earth didn't I think of that? (sanding foot down) oh myyyyyyyyy.. Link to comment
Moosedog Posted July 10, 2007 Author Share Posted July 10, 2007 Are your pegs in the lower position? Pegs are in the lowest position. I tried the belt sander and while my toes are certainly shinier, they are no thinner I have a pair of Alpinestars Ridge Waterproof boots and didn't think they were that thick in the toe. Does anyone else have this problem getting there boot under the shifter? Link to comment
ESokoloff Posted July 10, 2007 Share Posted July 10, 2007 Are your pegs in the lower position? Pegs are in the lowest position. I tried the belt sander and while my toes are certainly shinier, they are no thinner I have a pair of Alpinestars Ridge Waterproof boots and didn't think they were that thick in the toe. Does anyone else have this problem getting there boot under the shifter? No but I have the pegs in the highest position (for max clearance) Link to comment
Moosedog Posted July 10, 2007 Author Share Posted July 10, 2007 Are your pegs in the lower position? Pegs are in the lowest position. I tried the belt sander and while my toes are certainly shinier, they are no thinner I have a pair of Alpinestars Ridge Waterproof boots and didn't think they were that thick in the toe. Does anyone else have this problem getting there boot under the shifter? No but I have the pegs in the highest position (for max clearance) I will have to look closely at the shift lever/footpeg relationship tomorrow. I just can't wrap my brain around the idea that by having the footpeg higher it offers MORE clearance for the toe of the boot under the shift lever. Seems like the opposite would be true................. Link to comment
ESokoloff Posted July 10, 2007 Share Posted July 10, 2007 Sorry I did not make my self clearer.... Pegs in the hi position for maximum peg/ground clearance in the corners. No issues with boots. Link to comment
hopz Posted July 10, 2007 Share Posted July 10, 2007 Not totally sure it will help you, but on my R1100R I had the same issue and adjusted the shifter higher to give more clearance. It is not that hard, just be sure to remove the little circle-pins and adjust away... put the pins back when done. No problem. Link to comment
hopz Posted July 10, 2007 Share Posted July 10, 2007 OK- I went outside and looked at my K12RS... the lever is attached to am arm with an Allen-head screw. My owners manual says to loosen that set screw and move it to the higher position then tighten the screw. Apparently there are two positions. Up and down. Link to comment
Moosedog Posted July 11, 2007 Author Share Posted July 11, 2007 OK- I went outside and looked at my K12RS... the lever is attached to am arm with an Allen-head screw. My owners manual says to loosen that set screw and move it to the higher position then tighten the screw. Apparently there are two positions. Up and down. I tried this last week thinking it was a simple fix, but when the lever was off there was no alternate position - no up or down - that I could see. Could it be the difference between the model years of your bike vs mine? Link to comment
DaveTheAffable Posted July 11, 2007 Share Posted July 11, 2007 Does anyone know (silly question on here, I know) how to adjust the shift lever so it is a bit higher and easier to get a motorcycle boot under it without having to dislocate my ankle? Try this... (?) http://www.nwlink.com/%7Epaulcl/shiftermod/index.htm Link to comment
