ignition switch, R1150RT 2002
Xavier
People,
The 2002 R1150RT kept cutting off. What did I do? I thought it must not be getting gas or fire so I replaced the fuel filter($30.00). No change. Once I got it running again I noticed when I turned the handle bars it would cut off.
So, I came here and found out the wiring harness that goes to the ignition switch was the problem. If you wiggled the wires right where they go into the switch it would either run or cut off the bike. I ordered the new harness($94.00) its about 2 ft. long with two easy plug in terminals it should fix it I am 99% sure. So I hope this will help someone and I promise to send in a donation very soon.
