KCScott Posted July 5, 2007 Share Posted July 5, 2007 I get water inside the headlight when driving in the rain. This has happened since the bike was new. Does anybody know if there is a service bulletin concerning this? Is this a common problem? Thanks Link to comment
Eschelon1 Posted July 5, 2007 Share Posted July 5, 2007 Don't know of any service bulletins off hand but you should'nt be getting water inside the lens. You may have a warranty claim there. The only way you might be getting water is if the rubber boot that seals off the headlight/Hi beam connectors is loose, ripped, torn, etc... Link to comment
Ken H. Posted July 5, 2007 Share Posted July 5, 2007 Not common, but not unheard of either. The whole assembly has to be replaced. If your '04 is still in warranty it should be covered. Link to comment
Laffo IBA#34115 Posted July 5, 2007 Share Posted July 5, 2007 Mine has the same issue and has been complained about. Turns out that there is a service bulletin and the problem is not a problem according to BMW. They say that it is normal and that there are vents at the top to take care of the condensation that temporarily occurs after riding in the rain or washing it. I have been shown the service at Morton's BMW. Hope this helps. Link to comment
ElJefe Posted July 5, 2007 Share Posted July 5, 2007 Well, if that's true, then what would be the harm in drilling a couple small drain holes (or weep holes) in the bottom of the housing? Link to comment
KCScott Posted July 5, 2007 Author Share Posted July 5, 2007 Thanks for all the help. I will talk to my dealer see what they say. I think its poorly designed if they expect water to get in. It leaves a haze on the inside of the glass which of coarse irritates me! regards, Scott Link to comment
Kroref Posted July 5, 2007 Share Posted July 5, 2007 Let us know what response/solution you get at the dealers. My 04 has the same problem once in a while. Link to comment
