KiwiRiden Posted July 2, 2007 Share Posted July 2, 2007 I hope someone can give me some advice. My 04 RT-P (55,000 km) recently started vibrating a lot more. I will do a TB synch, and look for the usual sources, but the vibration is a lot worse on the left hand side through the handlebar and footpeg. Any thoughts on what I should start fixing first? Link to comment
ninermatt Posted July 2, 2007 Share Posted July 2, 2007 It sounds like your on the right track with the throttle body synch, But first I would check the valves. You'll be amazed at how smooth a boxer twin can be. Link to comment
4wheeldog Posted July 2, 2007 Share Posted July 2, 2007 Vibration felt more on one side of the MC than the other would make me want to check motor mounts. When the motor vibrates on an opposed twin, the shakes are equally present side to side. I suspect you have a loose mount. Link to comment
