Bheckel169 Posted July 2, 2007 Share Posted July 2, 2007 I recently had my 6,000 mile service and since that time, I've been getting the oil needed icon on my screen. After awhile it goes away, but I don't need oil. I've checked that several times and even added a little more to make sure it was slightly higher then the middle of the sight glass. Anybody have the same problem? Bruce Link to comment
marcopolo Posted July 2, 2007 Share Posted July 2, 2007 If you just had a service done, why isn't the oil up to the top of the sight glass? Mine always is after an oil change, and stays that way for quite a while. I've never had the oil icon appear, but then I always keep my oil near the top of the sight glass. Try it; you might find the icon disappears. Link to comment
LuckyLeif Posted July 2, 2007 Share Posted July 2, 2007 Doesn't the oil icon indicate a problem with oil pressure rather than low oil volume? Link to comment
dyvking Posted July 2, 2007 Share Posted July 2, 2007 I recently had my 6,000 mile service and since that time, I've been getting the oil needed icon on my screen. After awhile it goes away, but I don't need oil. I've checked that several times and even added a little more to make sure it was slightly higher then the middle of the sight glass. Anybody have the same problem? Bruce There was a service bulletin out on my '06. I just had the 18k service, and they performed a fix under warranty. Same issue described, and identical to the issue described in the service bulletin. Inform the dealer and ask to get it fixed. Link to comment
Bheckel169 Posted July 2, 2007 Author Share Posted July 2, 2007 Thanks. I knew somebody on this forum would recognize a similar problem. I'll take it in and have them fix the problem. Now I just have to figure out what to do with the other icon that shows up on my screen that eerily looks like a naked woman. Only kidding! Bruce Link to comment
