Knighthawk Posted June 29, 2007 Share Posted June 29, 2007 ...holding the windscreen on my '04 RT? Anyone?? Thanks Link to comment
Rob L Posted June 29, 2007 Share Posted June 29, 2007 Mine are 3mm Allen socket head screws, not torx. Link to comment
Knighthawk Posted June 29, 2007 Author Share Posted June 29, 2007 I'm posting from work, so I can't check. I thought they were torx, but maybe they are allen. Link to comment
Boffin Posted June 29, 2007 Share Posted June 29, 2007 I'm posting from work, so I can't check. I thought they were torx, but maybe they are allen. Yup, Allen on my '04 RT Andy Link to comment
Knighthawk Posted June 29, 2007 Author Share Posted June 29, 2007 OK, thanks all. I must have had a brain fart. Link to comment
Steve_Witmer Posted July 1, 2007 Share Posted July 1, 2007 The Allen (hex) screws are on the front of the windscreen. If you then want to remove the black plastic strips from the windscreen, you need a #10 Torx bit for the two center screws accessible from the back. Link to comment
Bill_Walker Posted July 1, 2007 Share Posted July 1, 2007 The Allen (hex) screws are on the front of the windscreen. If you then want to remove the black plastic strips from the windscreen, you need a #10 Torx bit for the two center screws accessible from the back. I can't swear to what's stock, since my '04 1150RT had an aftermarket screen on it when I got it, but my bike has no fasteners attaching the black plastic pieces to the screen. They're just held on by the allenhead screws on the front, two per side. Your 1100 may differ. To the OP, when you get the screen off, watch out for the little rubber bushings that go between the screen and the brackets at each screw hole. They usually stay on the brackets when you pull the screen off, but they're very easily knocked off and lost. I make a point of taking them off and putting them with the screws. Link to comment
