tires
taters
it's to long a story to write now but could someone give me my tire size for my 2004 1150 rt. its in the dealers shop along with my manual. front is 120----- rear is 170...i think but lt me have this info and i will give you the details of this horror story. gonna cost me 3500 for a bad tire install at a yamaha dealer.woe is me help
thanks a lot. i got 2 tires from sw moto.great service. i took them to a yamaha dealership to install them. the installer put the lug nuts on wrong and stripped some bolts. also didn't torque them right. screwed up my rear disk tire and i think the bmw mechanic said it screwed up the drive line or something like that. they wrote it all up and said the bill will be $2700, the mechanic said i was lucky the rear wheel did not fall off and killed me. when i get the bill and pick up the bill and i will go to the yamaha dealership and ask for $2700 and another $750 for a rental car. the dealership said they will write up the mistakes the installer made in detail. so i will take them to small claims court and hopefully get my $3500 back.
You'll most likely end up in court.
See what your insurance can do for you then let them handle it.
Make all the calls and start a paper trail before you or pay out any money to build your case and make it stronger.
good advice. it is gonna take at least 14 days. i went to the yamaha dealership and told them i needed a copy of the work. i did not tell them why.. they gave me a printout. then i wrote to sw moto and asked for a receipt for the time period 2 days before the work was done they said ok they will send it. and the bmw dealership said they will write a concise letter detailing all thethings done wrong and give me the parts. so heres hoping .i will call my insurance agent tommorrow. thanks for all the advice
russell_bynum
You would have to be monumentally incompetent to screw it up that bad. The front is pretty much exactly like the front on every other bike out there.
The rear is dramatically easier. Just remove four lugs, pull the wheel, change the tire, put the wheel back on, and put the four lugs back in.
Even a chowderhead like me can do that without mucking anything up.
My advice: Never take ANYTHING to that shop again. If you break down in front of that shop and need to use the phone, push your bike to the next place...even if it is 10 miles uphill in the 110-degree heat. Whatever they've got going on in there, you don't want to risk getting any on you. eek.gif
Paul Mihalka
Just in case, on a R1150 you have to remove the brake caliper before you remove the rear wheel, as the brake disk is attached to the wheel. No big deal.
Taters,
Sorry to hear about your screw up.....what a mess!
Anyway, you have learned a lesson that I had a long time ago.
Better to remove the wheels yourself and then just take the wheels to get the tires mounted. Oh! and to be safe, check your rims to see if the buggers marred or chipped them - DAMHIK! Shops generally give tire work to the lowliest of their staff eek.gif
Good luck and DLTBGYD thumbsup.gif!
Boy oh Boy there are some confused thoughts in there
screwed up my rear disk tyre (what is that?) the tyre or the disk?
Stripped some bolts (how)
screwed up the drive line or something like that?
I smell a rat here!! one who likes to rip people off
the rear disk , i will give you the full report if you want it when i pick up the bike. i am no thief. i am just ignorant when it comes to bikes and their parts. i should get the bike back in 2-3 weeks and i'll write verbatim what the service manager wrote.
Cross threading the lug bolts could cause all the listed damages. The bolts and threads in the hub would be damaged and if the bolts weren't fully tightened, the wheel and rotor would slip and could elongate the mounting holes.
Take lots of pics to go with your write up from BMW. The more ammo you have the better. Document, document, document!!!!
ISYHTRAH
thanks for the advice i just called the dealership and left a message telling them i will be dropping off a camera for them to take pictures. thanks for the idea.i'll let you know how this plays out in the weeks ahead. i won't get the bike back for at least 2 weeks.i am seeing a lawyer a week from tuesday. then i will confront the dealership. i will have a receipt for the tires by then and i have a copy of the dealerships invoice where they installed the tires. and i will have the dealerships write up of specifically what the damage is and how it happened. thanks all
