Dances_With_Wiener_Dogs Posted June 27, 2007 Share Posted June 27, 2007 Seriously! I have some mirrors that have a spring and ball joint, so you can fold them out of the way on the trail. However, they are far too loose, rendering them useless at highway speeds. The mount cannot be tightened...and the mount isn't moving anyway, it's the ball socket tension within. Suggestions? Link to comment
Dances_With_Wiener_Dogs Posted June 27, 2007 Author Share Posted June 27, 2007 Blue Thread Lock ??? The problem is that it's handy to move them a little, but not during the commute. I wonder if the bearing has just worn down? Link to comment
Joel Posted June 27, 2007 Share Posted June 27, 2007 A wise rider with many more miles than I'll ever ride suggested to me once that fingernail polish or Testor's model paint on the ball(s) will do the trick. It creates friction in the joint and weathers reasonably well, but if it wears off you can reapply it easily and inexpensively. Link to comment
Dances_With_Wiener_Dogs Posted June 27, 2007 Author Share Posted June 27, 2007 Thanks Joel...I'll give it a go. Link to comment
Bud Posted June 27, 2007 Share Posted June 27, 2007 Thanks Joel...I'll give it a go. Hmmm, fingernail polish on your balls? Thinking this might smart just a little as it drys. Link to comment
KMG_365 Posted June 30, 2007 Share Posted June 30, 2007 Thanks Joel...I'll give it a go. Hmmm, fingernail polish on your balls? Thinking this might smart just a little as it drys. I sure as heck wish we had archived "ToxicAgain's" "My balls hurt" thread from a few years back. I'd love to read that one again! Talk about laughing until your sides ache! Link to comment
Lawman Posted June 30, 2007 Share Posted June 30, 2007 Seriously! However, they are far too loose, rendering them useless at highway speeds. Suggestions? That's just the result of old age..Get used to it. They won't get any better.. Link to comment
notacop Posted June 30, 2007 Share Posted June 30, 2007 Blue Locktite.....Blue Balls...That hurts.... Link to comment
WURTY Posted June 30, 2007 Share Posted June 30, 2007 Mine touch the water when I sit on the pot Link to comment
Bud Posted July 1, 2007 Share Posted July 1, 2007 Mine touch the water when I sit on the pot But the sheep don't mind. Link to comment
eddd Posted July 1, 2007 Share Posted July 1, 2007 That's just the result of old age..Get used to it. They won't get any better.. There's always Viagra. Link to comment
Roger_R Posted July 2, 2007 Share Posted July 2, 2007 +1 on the fingernail polish. You could always ad a bit of valve lapping compound also. Valve lapping compound is cheap, couple of bucks at a parts store and you can use it on the end of your scewdiver for those really tight phillips screws, more bite on the tip of the screwdriver. Link to comment
