SAAB93driver Posted June 26, 2007 Share Posted June 26, 2007 My ACE Hardware of all places carries it for $4.99 a pack. Good stuff, but will turn your underware pink. Link to comment
E30TECH Posted June 26, 2007 Share Posted June 26, 2007 but will turn your underware pink. Like your underwear isn't pink when you put it on Link to comment
SAAB93driver Posted June 26, 2007 Share Posted June 26, 2007 but will turn your underware pink. Like your underwear isn't pink when you put it on On a good day that is the only color it is. Link to comment
BruceWA Posted June 26, 2007 Share Posted June 26, 2007 Some years ago picked up a tip from an ISDE rider, Bag Balm. Works very well, at least for off road "applications". Never tried it for street riding. Link to comment
E30TECH Posted June 26, 2007 Share Posted June 26, 2007 but will turn your underware pink. Like your underwear isn't pink when you put it on On a good day that is the only color it is. Link to comment
s3steve Posted June 26, 2007 Share Posted June 26, 2007 but will turn your underware pink. Like your underwear isn't pink when you put it on On a good day that is the only color it is. Link to comment
ronest Posted June 26, 2007 Share Posted June 26, 2007 Hello: Does anti-monkeybutt work? Or is it hype? RD Link to comment
Husker Red Posted June 26, 2007 Share Posted June 26, 2007 I've been using it on trips for a couple of years. I think it certainly helps, but I'm not sure that it's any better than any other talcum / baby powder. I just like the name better than the others. Link to comment
TampaJim Posted June 26, 2007 Share Posted June 26, 2007 I have found that grocery store corn starch works about the same and for a lot less $$$$. I use the empty monkeybutt canister as a dispenser for the corn starch. Link to comment
notacop Posted June 26, 2007 Share Posted June 26, 2007 I find that staying away from monkeys works for me Link to comment
tallman Posted June 26, 2007 Share Posted June 26, 2007 I use it. It works for me. They have eliminated some of the stuff that aids in bacteria growth found in regular powder and added some other goodies. Placebo? Maybe. Great ju-ju IMO. YMMV. See how well it keeps the monkey away? Link to comment
jbr7t Posted June 26, 2007 Share Posted June 26, 2007 I use regular corn starch powder and I wear Under Armour boxers, gym shorts (non cotton) and an under armour loose gear shirt. Then I put my riding gear over it. These have worked well for me. Link to comment
johnlt Posted June 27, 2007 Share Posted June 27, 2007 I spent many years doing long distance bicycle riding and always used "Udder Butter" and it worked great. I now use it for "long" rides on the RT (along with bicycle shorts). You have to buy it at a womens store but I get my wife to do that! Highly recommended. Link to comment
Bob Palin Posted June 27, 2007 Share Posted June 27, 2007 I've tried the Monkey Butt Powder and several regular talcs but Mexsana medicated powder works noticeably better than anything else for me. It's no miracle cure though... Link to comment
hANNAbONE Posted June 27, 2007 Share Posted June 27, 2007 Some years ago picked up a tip from an ISDE rider, Bag Balm. Works very well, at least for off road "applications". Never tried it for street riding. yOU aRE cORRECT, sIR..!! Link to comment
ElevenFifty Posted June 27, 2007 Share Posted June 27, 2007 Bicylcle shorts with the pad removed (seam ripper and 20 minutes work) ... also Wally World sells some 'Athletic Wear' stretch shorts without any padding. I find that the moisture is wicked away and the itchy butt problems are GONE! I won't go on a ride of more than a half hour or so without riding shorts. I also use a wool pad which does promote a little air circulation. Link to comment
BluesTraveler Posted June 28, 2007 Share Posted June 28, 2007 Under Armor and Gold Bond powder. Gold Bond also makes an extra (green bottle)strength. Works well but is one of those things after putting it on your not sure if it burns or is awfully cool. So I went back to the normal(gold bottle) Gold Bond. I use to race a lot of desert and moto-x years ago. Before all the synthetic clothing we use to wear pantyhose under out leathers. Sounds really strange but was amazing how well they worked in keeping the rash down. Link to comment
BruceWA Posted June 29, 2007 Share Posted June 29, 2007 LD Comfort riding shorts are fantastic. Just got mine and with two rides the comfort level is amazing. Link to comment
Agent86 Posted June 29, 2007 Share Posted June 29, 2007 Try Bengey, you won't be able to set down and get Monkey Butt. Link to comment
