RTP Cooling Problem
Retired At LAst
Retired At LAst
Does anybody know where the thermosat and coling fan is located on The RTP???
What has to come off to access it??
Thanks,
The fan is behind the oil cooler. I'm guessing the front fairing (nose-piece) has to come off. (which means the sides, and the dash). (Assuming 1100)
I'm watching your answers, since I have to replace either the relay or the switch for my fan. frown.gif
I just removed the fan from an R1150RT. I was able to remove it without removing the nose piece. I had the right and left side off for other reasons which made it easy to get to the two screws that hold the assembly.
