Another boring tire question-uneven wear left side
ahirsch
Posted
It appears my 1100 RT pulls to the right. My new tires after 1000 miles are already wearing and leaving a ridge on the left side. eek.gif When I bought the bike the tires that it came with were also worn heavily the same way. What can be done??? Help??? confused.gifconfused.gif
Posted
You're screwed.
This website is actually a big put-on. None of us actually own BMW bikes, and you are the unwitting recipient of a cruel practical joke for buying a beemer. We've been waiting for you, and it's been a long time coming. Leslie - you can send the boobie prize, we have a winner!
We all are riders, no doubt. But the PTTR phenomenon is well known amongst us, and to wit we have avoided purchasing the famed BMW motorcycle for that very reason. The damned, dirty PTTR, destroying tires and the confidence of riders worldwide.
There's nothing you can do - many have tried. Some of the pitiful attempts at remedies are:
- Removing the shim in the back wheel to more closely align the track of the rear with the front - useless.
- No longer ride in America - our roads are crowned for drainage - fruitless.
- Make three rights instead of one left - this is still under investigation and might have merit.
- Buy ME880 tires to thwart off the early onslaught of the left-side groove apparent in the softer tread of more performance-oriented tires - hopeless.
- Hang off to the left as a part of your normal riding posture, thereby leaning your bike to the right. Only Russell does this, but he doesn't ride a BMW anyway - goofy.
You can do a search on "PTTR" - but you may need to go back a few years for a more detailed explanation than this silly reply. The only serious thing I've said of course is "You're screwed".
Posted
So dragging my right foot on the ground probably won't make a difference either. grin.gif
Posted
Nope, dragging the right foot won't help, but dragging the left might,
I'm on ME880 tires right now, and I see a less PTTR and wear compared to the MEZ4's I had on it before.....
Posted
No matter how hard I try, my tires wear out after 6-8 thousand miles. Some show the left side wear, some fronts cup from too much brake on curvy rodes, some wear the middle droning the interstates from here to there.
It's a conspiricy of the DOT and the tire people.
Posted
It's actually a "service" provided especially for BMW owners, who aren't happy unless thier complaining about something or other, related to the cost of owning a BMW motorcycle. eek.gif
This way if everything else is running "tickety boo" on our bikes, we can at least "fall back" on what it costs to keep rubber between us and the pavement, until the the next cost crises rears it's ugly head. grin.gif
Posted
I love the responses!! lmao.gif Figured I was screwed and will just have to deal. The ridge that is building is way bigger in my mind and thus causes nightmares and concern. The nightmare is going to be realized when 3000 miles occur however, because I will probbaly be looking at a new set of tires. Maybe I will try a harder tire, as I am on the z6 now. The previous set were Z4. Switching brands won't help? Less tire pressure?
Posted
Ahirsch, there have been many threads on this site about PTTR (pull to the right) & L/H tire wear.. Here is a thread from a short time ago with about the same question..
Click Here PTTR
Twisty
Posted
I just switched from a Z4 to a Z6 a while ago, so far no noticable wear pattern but I've only put on about 500 miles.
My experience is that it's the last 1000 miles where the uneaven wear really start to show.
I would also point out that I have been in situations were going around a curve (too fast) I felt that there was "no way" that I was coming out unscathed, and the Z4's held the road and gave no sensation of slide.
So that being said, I would rather change tires a little more often knowing that they will "stick" when the need arises. thumbsup.gif
Posted
Andrew,
I seem to have less of this effect on the Z6s (last 3 or 4 sets) than I did on the Z4s (first 3 or 4 sets). I also get about 12-13K miles in contrast to others. It appears that mileage varies greatly amongst subscribers to this forum with no obvious reason for the differences. I did remove the shim on the rear wheel which seemed to reduce the PTTR and may have influenced the uneven wear. It didn't change the total mileage on a set of tires.
Posted
Past discussions on PTTR have ranged widely in their logic and intent. Apparently, the PTTR is widespread but I refuse to believe that the problem can't be diagnosed or corrected.
I used to be an advocate for engine torque causing the problem until it was pointed out that not all BMW, or other shaft driven bikes, pull to the right.
My favoured hypothesis is a misalignment of the fron and rear wheel axis. I cannot however explain why misalignment never causes a pull to the left.
If the alignment was as in the diagram below, it would cause camber thrust in opposite directions on the front and rear causing the bike to continually turn one direction. If this geometry was in error, then it should be able to be corrected by making an adjustable bush on one side of the front telelever. Adjusting it back or forward would tilt the steering from side to side and either correct or counteract the PTTR.
I don't claim it to be THE answer, just an idea.
Posted
It is either PTTR or it is the crowned US roads and left turns are longer than right because we drive on the right.
Pick which belief you choose and make it your religion around here. Radical believers for both.
Now that is out of the way, do you want to talk oil and oil filters (some of which are "crap" and you can see it by just looking at them).
A word to the wise: Don't mention Fram. lmao.giflmao.giflmao.giflmao.giflmao.giflmao.giflmao.giflmao.giflmao.giflmao.giflmao.gif
Posted
What tire pressures are you running? Some abnormal and premature tire where can be attributed to under-inflated front and over-inflated rear tire pressures.
Posted
We ride on the left side of the road and PTTR still prevails. It's puzzling to think that if an error in geometry exists, why does it always favour PTTR and never PTTL? confused.gif
Posted
Haynes, they pull to the right because they are heavier on the right.. The trans gears & rear drive shaft, rear brake, etc are right of center..
Put some weight in the L/H pannier & they will go down the road fairly straight..
Look at most of the oil head fall over damage,, it is usually on the R/H side (ever wonder why?)
Twisty
Posted
Twisty
+1 I always keep a couple things in my left sidecase. When I load up for a trip I make sure the heavier items are on the left and the bike actually tracks pretty straight. One time I even experienced pttL yes, left...of course I had all the parts for my 12,000 mile service in my left case! thumbsup.gif
Posted
The weight distribution is very unlikey to be the absolute cause as the severity of the PTTR varies from bike to bike. Both the R1150RTs that I've owned have tracked perfectly straight without any steering inputs from me and without weight compensation.
However, around two years ago I was asked to ride a friend's bike to measure the PTTR which was quite prominent and wearing on even a short ride.
Weighting the left side compensates but does not correct the geometry.
