xoomerite Posted June 18, 2007 Share Posted June 18, 2007 Can these be installed on the bags for the R1200ST? They seem to be the same as the bags on the R1200RT. It seems that the bags would have to be disassembled in order to do it. If so, how? Link to comment
Jim VonBaden Posted June 20, 2007 Share Posted June 20, 2007 It can be done, but it is a pain. You have to remove all those screws, and be careful not to dislodge the locking mechanism when removing the liner. Here is the lock. I would prefer to use ROK straps to the frame and rear rack like this: Jim Link to comment
RedMac Posted June 20, 2007 Share Posted June 20, 2007 +1 on the ROK straps.. good stuff Link to comment
santabarbaric Posted June 28, 2007 Share Posted June 28, 2007 If I may humbly add. One must ALSO remove the four hinge bolts! (At least that is the case on the R1200RT) Also, all fasteners use a 20 Torx, AND note the different size & length screws when removing! (There are 3 different types of screws, not including the hinge bolts) If all this is observed, the inner lid will pull directly out without trouble. Link to comment
