Lost my twin max adapter ends ???
Ralph
Yep, absent minded. I lost the short hoses & adapters. Who sells the ones that came with the balancer? I cant find the prober fittings around here. Thanks
You should be able to pick them up at any auto parts store I would think. All you need is a foot of proper diameter rubber hosing (that matches what is on the throttle body) and 2 adapters to go from the twinmax hosing to the new hosing
ShovelStrokeEd
Down in those sizes, metric or SAE makes not much nevermind.
Snug fit on the hose barbs at the throttle bodies is paramount. If you have to work a little to get them on, so much the better. Stepped adaptors for vacuum hoses are available at any decent auto parts store. Bring a small sample of the hose you have with you. Again, these things are tapered so you can usually find what you will need.
