steveg Posted June 16, 2007 Share Posted June 16, 2007 I checked my abs fault codes and came up with 7 . I flushed the wheel circuits and the hydro unit and the fault came right back by the time I reached the end of my driveway. description of code is ABS CONTROL UNIT my question to you , is that the computer or the hydro unit for code 7 steveg Link to comment
T__ Posted June 16, 2007 Share Posted June 16, 2007 I checked my abs fault codes and came up with 7 . I flushed the wheel circuits and the hydro unit and the fault came right back by the time I reached the end of my driveway. description of code is ABS CONTROL UNIT my question to you , is that the computer or the hydro unit for code 7 steveg Steve, first, is your ABS failure light on? If not makes sure you are testing for code 7 correctly.. If your ABS light is ON then maybe this link will help you determine if your code 7 is in the ABS unit itself or you possibly have an external problem.. http://www.ibmwr.org/ktech/abs-diagnostics.shtml Twisty Link to comment
steveg Posted June 16, 2007 Author Share Posted June 16, 2007 thanks twisty I,ll check that out, unfortunatly I put all of the tupperware back on thinking that I had to replace the control unit and was gonna ride as is till I could find a used one . new one is 1500. from chicago I,ll let you know how it works out steve Link to comment
