Aux Lighting: narrow beam from under the fairing?
Michael_T
Anyone have any suggestions for a narrow beamed or pencil beamed driving light(other that the PIAAs) for under the fairing of an 1150RT?
Every thing that I've seen is too big to fit.
Just seeing what's out there that the Gods of all Electric have used and are happy with (or unhappy with as the case may be).
thx
Michael
To fit under the fairing, it will have to be no bigger than a PIAA 1100x, because that just barely clears everything it has to clear. Check the dimensions of the 1100x, check the dimensions of other lights, and lots of luck.
I like the center light between the forks, it clears the oil-cooler just fine. needs a homemade bracket though, not too hard if you are handy.
