TheGeep Posted June 12, 2007 Share Posted June 12, 2007 OK, new K1200GT, just about 600 miles on it, and the front brakes howl badly when the speed drops to under about 10 MPH. Seems to be worst before they're warmed up, but never goes away entirely even after an extended around-town run. I'm about to take it in for it's 600 mile service, but would like to be armed with some knowledge before I go. Anyone out there with a good idea what this might be? Link to comment
10ovr Posted June 12, 2007 Share Posted June 12, 2007 I use (wellworthproducts.com)Squeal Aid,Have used for 15 years on cars and bikes,,Rough up pads,spray on,let dry,,My LT could wake the dead,,Dealer is going to tell you its normal!!Soft braking well glaze the pads,Noise is comen with link brake sys..Hope this helps,, Link to comment
R4ND0M_AX3 Posted June 12, 2007 Share Posted June 12, 2007 The R1200ST that I have squeeled just before reaching a full stop. There was a bulletin for it and I had it taken car of. Not sure if the K bikes use similar brakes. They now use some rubber washers between teh rotor and the wheel. Link to comment
elwoodpone Posted June 13, 2007 Share Posted June 13, 2007 Just had a K1200R loaner and thought it was just beat -- 4k mi-- same wild brake noise, never asked for an explanation given the goofey throttle response and even more than usual BMW gear case gnashing. Response, "They do that..." Ommmmmmmmmmmmm! Link to comment
Hoover Posted June 13, 2007 Share Posted June 13, 2007 K1200S did the exact same thing. Dealer says it is normal because of "high perfromance" brakes. Sounds like bunk to me, but they told me to just brake harder. They also told me it gets better over 1500 miles. Have to say it did get better, but not still gone. I have changed my riding style to brake harder from higher speeds (10 and above) and utilize the rear brake more under 10 mph (also dealers suggestion) . It has greatly reduced the brake noise, but time to time I forget and when I am doing allot of city riding it comes back. Link to comment
Sparky_in_Houston Posted June 13, 2007 Share Posted June 13, 2007 I see you rode a 2003 GT and now a 2007. I have a opportunity to get 2003. In your opinion, should I hold out for a used 2006 / 07? Also have an opportunity for a 2005 R1200 RT. Any opinions? Thanks Sparky Link to comment
TheGeep Posted June 14, 2007 Author Share Posted June 14, 2007 The only reeason I chose the GT over the RT was the quicker acceleration. Having put a few miles on it, I think now I would have been perfectly happy with an RT as well, and saved a considerable amount of money. As for the old GT vs the new version, there just is no comparison. The new version is incredibly improved over the old one. Now, does anyone know what my brake noise might be and how to correct it? Link to comment
Calvin (no socks) Posted June 16, 2007 Share Posted June 16, 2007 When my Beta '05 "S" was new it made a rear rotor howl of sorts.. It eventually went away with use... same rotors, same pads 25k miles later...Numerous sets of tires...... Link to comment
