KentuckyBlue Posted June 10, 2007 Share Posted June 10, 2007 I'm looking for lights for the rear of my 2002 R1150RT-P> The Code 3 LED's were removed and I would like to get something similar that is approved for civilian use. The rack where the lights were mounted have 2 openings measuring 2 3/4" x 6 3/4" where the lights were. There are also 2 openings for round lights around an inch diameter. Any suggestions? ray Link to comment
sundaeman Posted June 11, 2007 Share Posted June 11, 2007 If they're facing the rear you should not have any issues with red LEDs for additional brake, turn or running lights. I'd go to the Code3 (or Whelen) sites to get some ideas for replacements. There is a thread at ADVrider covering some of this too, just search on Whelen from the last month or so. I assume the round lights are in the radio box facing the sides, I'd look at some steady burn red or amber marker lights (you may be able to enhance your turn signals at the rear too). Again I'd check the Code3 site as a starting point. Just some random thoughts. Link to comment
