Silver_Point_1 Posted June 9, 2007 Share Posted June 9, 2007 Ok, I have a '05 R1200ST that I am getting ready to put new tires on. I went and bought a "Pro Motion" combination hex tool (19, 22, 24mm) to remove the front wheel. The 22mm hex is too big for the axel. Do I have to get the "BMW 36 3 691 hexagon socket 22mm flats" tool or will something else work. If I have to get the tool how much can I except to pay. Thanks Mike Link to comment
Ben_Ricci Posted June 9, 2007 Share Posted June 9, 2007 Try this. It's technically (I think?) a shower head removal tool (about $2 at a hardware store) but it fits the front axle. Link to comment
duckbubbles Posted June 9, 2007 Share Posted June 9, 2007 Mike, the axle is 22mm. Perhaps you can file the 22mm portion of the tool you have a tad to make it fit. Maybe there is something like a burr that is preventing it from inserting. Frank Link to comment
Redbrick Posted June 9, 2007 Share Posted June 9, 2007 Try this. It's technically (I think?) a shower head removal tool (about $2 at a hardware store) but it fits the front axle. Thanks. ....Just bought one at Green Thumb Nursery in the plumbing section but paid a lot more than you....$2.39 plus tax....Same company (Taiwan) manufactured it too.. ...Fits very well... Phil.........Redbrick Link to comment
Fran Posted June 9, 2007 Share Posted June 9, 2007 I think it has been mentioned before, but the hex end of a Craftsman 13/16 Spark Plug Socket will work if you use a long extension and approach it from the left side of the bike. Fran Link to comment
Silver_Point_1 Posted June 11, 2007 Author Share Posted June 11, 2007 Thanks for the info. I ended up going to my local Cycle Gear store. They had a different brand (Motrax)of combo Axel Wrench. That one fit just fine. Thanks again, Mike Link to comment
bakerzdosen Posted June 11, 2007 Share Posted June 11, 2007 Ok, I have a '05 R1200ST that I am getting ready to put new tires on. I went and bought a "Pro Motion" combination hex tool (19, 22, 24mm) to remove the front wheel. The 22mm hex is too big for the axel. Do I have to get the "BMW 36 3 691 hexagon socket 22mm flats" tool or will something else work. If I have to get the tool how much can I except to pay. Just FYI, Motion Pro had a bad batch of 22mm hex tools go out. They're aware of the problem and will get you a new one if you contact them. I can't remember where I saw it (either an old thread here or advrider or some other board), but if you bought this one, you can contact them and get a replacement. Personally, I haven't bothered because my local shop ground the 22mm down for me (just a tad) so it now works. I should contact them, but alas, it works. Link to comment
Jim VonBaden Posted June 11, 2007 Share Posted June 11, 2007 Here is what I used. A 13"/16" Taiwan spark plug socket cut off. Jim Link to comment
elwoodpone Posted June 11, 2007 Share Posted June 11, 2007 I suppose this is a dopey question but: do they not give enough of a tool kit anymore to enable the removal of the wheels? Link to comment
keithb Posted June 12, 2007 Share Posted June 12, 2007 No dopey questions here and no they do not give you a tool kit anymore with the new bikes. I recommend you build one yourself. Many of us have had to go through this exercise with the newer hexheads BMW's. Link to comment
